All gauges on the inst panel are dead
Old Jun 14, 2004 | 04:43 PM
jerrygar's Avatar
1998 Dodge 3500 Ram 5.9 diesel. All the inst. gauges on the inst panel are dead- they do not indicated anything. RPM, fuel qty, oil press, oil temp, battery.speedometer, odometer. I checked all fuses under hood and in the cab, they are ok. Any ideas on where to start?
Old Jun 14, 2004 | 09:49 PM
thumper 549's Avatar
i would have to ask -how did you ck them???
Old Jun 15, 2004 | 07:25 AM
MOUSE's Avatar
sounds like the bus, or the cluster. I lost my cluster last week, took it to the dealer found the bus locked up.
Old Jun 15, 2004 | 05:48 PM
jerrygar's Avatar
Some one suggested I take out the inst cluster and reset the 2 connectors. I did that along with disconnecting the batt cables and that fixed the problem. Thanks for the response.
Old Jun 15, 2004 | 05:51 PM
jerrygar's Avatar
If the fuses looked good, I did nothing but take them out , look at them and put them back in. If the fuse wire looked the least bit out of the ordinary, I used a continuity tester on the fuse.
Thanks for the reply, Jerry
Old Jun 15, 2004 | 10:45 PM
I would strongly sugest you test your fuses as looks mean nothing
CORed
35
Mar 11, 2025 09:42 PM
coontz0473
17
Sep 22, 2006 03:52 PM
mkrenn
Feb 12, 2006 07:23 PM
dieseljerk
Jun 12, 2004 12:13 PM
Ghostrider
Sep 2, 2003 09:25 PM
