alarm won't stop!!!!!
Old Apr 16, 2005 | 12:57 PM
Dusty Ratcliff's Avatar
the alarm on my girlfriends 00' dodge just started going off this mornin & I can't make it stop, she bought the truck used & we don't have a remote for the doorlocks/remote, I've unhooked the battery cables & pulled the horn & security relays & it still won't start & if i plug the relays back in & hook up the battery cables the alarm starts again, help please, Thanks, Dusty
Old Apr 16, 2005 | 01:45 PM
Rare1's Avatar
Don't know for sure. On most cars if you turn the key in the door or in the ignition the alarm stops.
Old Apr 16, 2005 | 04:26 PM
piperca's Avatar
I, too, don't have a remote. On mine, there is a small red button switch, below the steering wheel, behind the kick panel ... I think they call it a valet switch. Maybe worth checking out! Hope this helps.
Old Apr 16, 2005 | 05:47 PM
ty diesel's Avatar
maybee you have the wrong car??? check the plates
Old Apr 16, 2005 | 08:52 PM
handymantim's Avatar
If it's a factory alarm I don't know what to do.
If it's an aftermarket alarm there is usually an inline fuse (or fuses) somewhere either near the alarm brain or near the power source (battery). If you can find that fuse (or fuses) and pull it (them) then your truck should start and operate normally.
Old Apr 17, 2005 | 04:11 AM
duner's Avatar
had a cell in the battery short out while i was inside a store once upon a time. came out to find the alarm going off. wouldn't reset, van wouldn't start. it is a furd but the story fits. replaced battery, back to normal.
Old Apr 17, 2005 | 06:08 AM
jrs_dodge_diesel's Avatar
Here is what you do if you have the key, and you know the location of the dash switch. If the remote dies, then unlock the door and open it, the alarm will go off like it should. Then turn the key to ON and push the dash switch. The alarm should stop. Its a fail safe in case the remote dies, but it only works if you have the key.
I have also had good luck with complete disconnection of the alarm brain. This has worked on 2 different brand alarms in 2 different vehicles. Find the brain, and disconnect the main connection. The vehicle will run like there is no alarm installed.
Old Apr 18, 2005 | 05:16 PM
Thanks guys, putting the key in the door & turning it back & forth done the trick, I got it fixed the other day, but my computer has been down, thanks again for the help, you really can't beat this site for this kind of info. thanks again, Dusty
slivertruck
25
Nov 8, 2006 08:35 PM
royta
Nov 6, 2006 08:19 AM
Valv
Apr 12, 2005 10:19 AM
04ctd
Oct 18, 2004 10:19 AM
