AC barely blowing
Old Sep 8, 2005 | 04:38 PM
RoadDawg's Avatar
AC barely blowing
Blower sounds like it is full blast but no matter where I put it it barely blows any air. It is cold thanks for the help
Old Sep 8, 2005 | 07:00 PM
dodgetech77's Avatar
Its sounds like the evap might be freezing up due to a faulty fin temp sensor located on the evap coil. i had to replace mine i also changed the location of it when i had it apart to the center of the evap coil. If its got warranty use it.
Old Sep 8, 2005 | 07:14 PM
drew03's Avatar
i noticed mine does not blow as hard when under a load. is this normal??
Old Sep 8, 2005 | 08:05 PM
doorguy's Avatar
Could be an actuator on one of doors or a door itself(recirculation door). If you have warrenty use it.
Old Sep 8, 2005 | 08:29 PM
handymantim's Avatar
My first guess is what Dodgetech said. Do a search for "freez" or "frozen" and see what you get. This has been a common problem for people who have their A/C on for long periods of time. A temporary fix is to turn off the A/C while leaving the fan blowing to melt the ice in the evap core. Once you feel air blowing again, turn the A/C back on. Repeat until fin tep sensor is relocated.
Old Sep 8, 2005 | 11:53 PM
RoadDawg's Avatar
It is with the start of the engine!!! It gets colder but no air flow in either vents!!!
Old Sep 9, 2005 | 10:18 PM
03 ant a hemi's Avatar
The problem you are describing is for the divertor door broken. The TSB to fix it is 24-004-03. Seems that the door mount points are to weak to sustain high air flow of the fan. Hope that helps.
Old Sep 16, 2005 | 08:02 AM
360ramcharger's Avatar
theres two vacuum lines beside the brake master cylinder on the engine side
close to the firewall, if one becomes unplugged you lose the abilty to open the dampers in the air box. it happend to me 2 weeks ago I plugged it back in and snugged it with a wire tie and it works good. your year may very in location but there there black hard plastic.
hope this helps!!
runamuk
Jan 14, 2006 07:48 PM
RoadDawg
Sep 9, 2005 01:54 PM
darrenG
May 26, 2005 01:59 PM
jfpointer
Jan 2, 2005 09:20 AM
