ABS & Brake light on
Old Aug 29, 2007 | 01:10 PM
fschiola's Avatar
Originally Posted by tornado
the manuals don't have one in the transmission or the transfercase well at least mine don't, I know the automatics do. The only sensor mine has in the transmission is the backup light. I would love to get this thing figured out it drives me nuts.
The only speed sensor your going to find with a 5 speed is on the rear diff, if you don't have 4 wheel ABS, then there are two in the front as well. If you've replace the rear speed sensor, and don't have 4 wheel ABS, replace your stoplight switch. They're around $12.00 at Auto Zone.
Old Aug 29, 2007 | 10:24 PM
big bubba's Avatar
Found the front sensors listed on mopar.biz. Also found in another post that if you remove the small connector from the ABS module you can use an ohm meter to check them. Tried it today and mine ohmed out between 800 and 1000 ohms. Am I just chasing my tail here?
Old Sep 4, 2007 | 12:18 AM
big bubba's Avatar
Checked the rear wheel sensor and it ohmed out at 1800 ohms. Is this high or about right?
Old Sep 6, 2007 | 08:41 AM
CTDboy's Avatar
Anyone got an answer on the correct ohms for the rear wheel sensor. I will ohm mine out when I get home tonight. I am having the exact same problem as big bubba. ABS and brake light on, speedo and cruise work fine, brakes shudder when the lights are not on. Just started yesterday. I also heard a rotational, speed sensitive noise on the way to work this morning.
Old Sep 10, 2007 | 06:53 PM
skymiles's Avatar
My ABS and Brake light came on last week but my speedo worked just fine. About three days later the speedo would not work until I got over 20 MPH. So I stopped by Dodge dealer and picked up a speed sensor for the rear axle part#1-56028187 AE and all is well again.
Old Sep 20, 2007 | 08:32 PM
big bubba's Avatar
Last Wednesday on the way home from work the lights where on, and I had also a rotational noise that turned into a grinding sound. Turns out the front left hub bearings went. Replaced it, but the brake lights are still on. Guess I'm going to try the rear sensor.
Old Sep 21, 2007 | 07:57 PM
00sport's Avatar
mine acted exactly as skymiles did, replaced the rear sensor and its all good now
good luck
Old Sep 27, 2007 | 09:52 PM
Nomad's Avatar
my park brake light and ABS lights are on intermitently also, i guess i'll try that part number and see if it helps...
Cheers!
Old Sep 28, 2007 | 05:17 AM
fschiola's Avatar
Cheers!
Some have found that with intermittent lights, a part of the wiring harness to the sensor has rubbed through and is grounding out.
Old Oct 30, 2007 | 06:20 PM
kevellis32's Avatar
Where exactly is the wheel speed sensor located on a 98 12v...is it on top of the rear axle? My cruise control works, BUT, the light does not come on that says "cruise" when I turn it on, and the spedo works fine
Old Oct 31, 2007 | 03:39 PM
Skidpilot's Avatar
Same prob w/ my 07
Yesterday evening I changed my oil/filter/and fuel filter. Today I was suppose to pull my skid steer up to my next job in the mountains. I haven't had to hook up my trailer in about a month and a half. I remembered that I had been having some problems with my trailer lights (a short that causes the fuse to blow when I have my headlights on...) anyway, I was looking for that fuse and it was about dark. I decided to deal with my trailer in the morning. Well, I look down and my ABS light and parking brake light are not going out...figured I must have pulled out a wrong fuse. Then on the way home I noticed that my odometer is stuck on the same # 13340ish. Is this not a fuse problem ? oh and in my shining mechanical form...messing with the fuses today my 4WD will not engage. aggghhh
Old Dec 11, 2007 | 05:21 PM
EverydayDiesel's Avatar
you ever figure this out?
ive replaced both abs sensors, the pumpkin sensor.
I hope its not dangerous to drive with the brakes pulsating like that. It only does it once in a while
azjeff
Aug 4, 2012 09:57 AM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
mr T
Feb 24, 2007 06:42 AM
Alexjoz
Sep 1, 2005 10:00 PM
