View Poll Results: what to do?
check injectors?
0
0%
glow plugs
0
0%
Voters: 0. You may not vote on this poll
98 24 valve 4x4 starting problems
Old Mar 17, 2009 | 02:12 PM
offshorextreme's Avatar
Need helps guys I run my truck on vegetable oil and diesel. It doesnt start without starter fluid i put it in gear and it just dies. I changed the fuel filter it was full of water i think i got bad diesel i flussed it and im still having the problem. I changed the hp pump and lp pump a year ago and i run a fass pump for the vegetable oil. I was wondering if my injectors were clogged i ran cleaner through the system and still no fix. Once it does run and i get going it has full peddle full power.
Old Mar 17, 2009 | 03:42 PM
olddodgetrucks's Avatar
you are going to have a hard time repalcing the golw plugs ,it seems you never find those little xxxx,s
Old Mar 18, 2009 | 12:56 PM
thumper549's Avatar
I suspect it is a fuel problem ,,,as injectors do not clog unclog.they are good or bad, not in between
Old Mar 18, 2009 | 03:35 PM
infidel's Avatar
My bet the problem is your glow plugs are missing.
Carboned up injectors is the reason why many of the people who once swore by veggie oil won't touch it any more.
Better to turn the the veggie oil into biodiesel.
fourthandgoal
88
Dec 27, 2011 05:39 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
RED99CTD
Apr 20, 2011 08:08 AM
V.R.Wheeler
Aug 4, 2007 01:00 PM
abc4yew
Mar 15, 2007 11:55 PM
