offshorextreme |
03-17-2009 02:12 PM |
98 24 valve 4x4 starting problems
Need helps guys I run my truck on vegetable oil and diesel. It doesnt start without starter fluid i put it in gear and it just dies. I changed the fuel filter it was full of water i think i got bad diesel i flussed it and im still having the problem. I changed the hp pump and lp pump a year ago and i run a fass pump for the vegetable oil. I was wondering if my injectors were clogged i ran cleaner through the system and still no fix. Once it does run and i get going it has full peddle full power.
