96 die at idle
Old Sep 2, 2006 | 09:40 AM
pittom's Avatar
96 die at idle
Truck die at idle like running out of fuel,then have to crank for 30sec to start and spouters for a while then ok. Runs fine from 1000 rpm up. Changde filters and cleaned pre heater,wires are burned off pre heater,read that it happens.
Idle was low turned it up no good unless i keep it at 1000rpm or higher.
was told it could be transfer pump,was a problen with then.
tom
Old Sep 2, 2006 | 09:42 AM
infidel's Avatar
Unless you have access to a fuel pressure gauge setup just replace the overflow valve
You won't find a better price than here
Precision Diesel Injection and Turbo Inc.
Marty Tompkins
888-734-7349
$35 + $7 shipping and handling.
Old Sep 2, 2006 | 07:06 PM
pittom's Avatar
Thanks that is it,I put vicegrips on return line and as soon as the eng started to die i clamped the line and it came back to idle.
DTR-username
Oct 3, 2016 07:46 PM
dodgesmoke
Feb 10, 2010 12:11 PM
DIESELRYAN3500
Aug 31, 2006 10:09 AM
SjLingenfelter
Jan 20, 2004 11:51 PM
midwestdually
Feb 25, 2003 10:42 PM
