94 ram where is the tack sensor?
Old Jan 13, 2007 | 09:18 AM
greenpower's Avatar
Unhappy 94 ram where is the tack sensor?
RPM Gauge not working, noticed alt not putting out, replaced it with new, notice in new alt box said, if you have a dodge cummins and rpm is not showing, the problem is tack sensor, ok WHERE IS TACK SENSOR ?? storm coming, Thanks
Old Jan 13, 2007 | 09:44 AM
infidel's Avatar
It's called the engine speed sensor (ESS) and is located at the dampener (lower pulley at the engine front). Follow the wires down to it. In fact your sensor could be fine, problem could be damaged wires or the sensor's connector near the top/front of the engine could be dirty. Also check the gap between the dampener and sensor, it should be about the size of a folded in half business card.
Txwelder
64
Dec 23, 2008 12:41 PM
weldman05
May 1, 2007 02:42 PM
Box5
20
Apr 2, 2007 10:40 PM
Fis Teck
Jan 21, 2006 05:00 AM
Pat
Jan 16, 2005 03:29 AM
