92 D350 won't start
Old Apr 13, 2008 | 05:26 PM
01sbc's Avatar
92 D350 won't start
Just as the title says, my first gen won't start. I was driving along and it quit, so I coast to the side of the road. I crank it around four to five times and it cranks, go about a half mile and it stops. Did this around three times. I had it pulled home to work on it. Well I changed the fuel filter and replaced it with a brand new fleetguard. I tried to bleed the air out at the nut there, no dice, the lift pump has no resistance. I check to see if any fuel is getting to the injector pump, there was, but very little. So I figured I had run it out of fuel. I took the line off the lift pump, put an air nozzle on it and with around 10-15 psi blew back to the tank, no bubbles. Okay, I ran it out of diesel.
So I got ten gallons today and poured in. Start to pump the lift pump, it starts coming out of the bleeder bolt. Whew, I'm in the clear, well not exactly. I bled it out to the bolt, tried to start it, nothing. Okay, so I bled the injectors, still nothing. I have no idea what's left to do with this thing, there is fuel getting all the way to the injectors. I'm going out of my mind and worried sick about it.
So anybody have any ideas?
Old Apr 13, 2008 | 06:41 PM
I bet the wire fell off the fuel shutoff solenoid. It's on top of the rear section of the pump, has two wires going to it. Make sure you have power there, and replace the crappy spade terminals with ring terminals when you get the chance.
Old Apr 13, 2008 | 07:27 PM
01sbc's Avatar
Think you might have a picture of that?
If this is so though, what would explain the fuel getting to the injectors?
Old Apr 13, 2008 | 08:06 PM
01sbc's Avatar
well, just an update, I went out and checked the wires...the were connected good. I'll check tomorrow with a multimeter to make sure or not there is power or not.
Old Apr 14, 2008 | 02:56 AM
01sbc's Avatar
To the top, I need some more suggestions please...I'm out of ideas.
Old Apr 14, 2008 | 06:33 AM
01sbc's Avatar
Could the timing have possibly slipped? Would a video help? I'm open to any and all suggestions
Old Apr 14, 2008 | 05:24 PM
The timing on a 1st gen can't slip.
Check for power at that solenoid when the key is on. When the shutoff solenoid is closed a little bit of fuel will still spray.
You may just need to bleed it some more if it really was out of fuel.
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
