91 Dodge Cummins Cam-Shaft Problem!
Old Jun 22, 2009 | 08:26 PM
canadakonrad's Avatar
looks like my cam-shaft doesnt turn no more. thatswhy my mechanical pump doesnt pump, result motor doesnt start. did anyone had something like that? how can that happen? motor just stalled all of a sudden. but i checked the mechanical pump by hand and it has alot of pressure. no fuel at the injectors though. thanks a lot...
Old Jun 23, 2009 | 07:08 AM
patdaly's Avatar
KDP got you?
Time to pull the timing cover and get a look see, it is not good though.
Old Jun 23, 2009 | 07:37 AM
maybe!? but there was no weird noises at all! just stalled. thanks
Old Jun 23, 2009 | 08:35 AM
cedardiesel's Avatar
ad removed but I agree with patdaly either that or the gear on cam has come loose some how in which most cases hardly ever happens
Old Jun 23, 2009 | 12:17 PM
patdaly's Avatar
FWIW, when my KDP got me on Greenie, I had no clue anything had happened, never a burp a clink, nothing, I just noticed the huge puddle of oil under her.
I did not lose a gear, but I doubt it would make as much noise as you would think.
Before you rip the whole front of the engine apart, does the VE front cover have the removable plug like the P7100 pump trucks do? If so, remove the cover and make sure the pump gear isnt turning, if it isn't I would almost say it is a certainty the KDP got you.
Old Jun 23, 2009 | 12:46 PM
thats the funny thing everything is turning i allready oppend that cover. now im taking the rest off(cover). its so weird. that **** cam shaft doesnt turn!!! for what else is it in charge? (the valve lifter and stuff?) thanks
Old Jun 23, 2009 | 12:47 PM
no oil under her either!!!
Old Jun 23, 2009 | 05:55 PM
patdaly's Avatar
If the gears are turning ( pump gear as well ) and the camshaft is not opening and closing the valves, the cam has snapped.
Crank gear turns all the other gears.
Take the valve covers off and turn it over, see if any are opening and closing. If part of them are, and part not, then between the 2 is where she snapped.
Can you get a picture of the front with the timing cover off?
Old Jul 3, 2009 | 08:05 PM
just wanne update. my cam-shaft has snapped. i dont know how that happens. its done...
Old Jul 3, 2009 | 10:29 PM
JFlory's Avatar
Thats crazy! Is your truck bombed out or something. I have never heard of a stock truck or even lightly modded Cummins snapping a cam. Only ones doing that stuff are the 800+hp monsters out there, not the '91 goat pokers.
Sorry about the luck.(still shaking my head)
Old Jul 4, 2009 | 07:26 PM
ya it is crazy !!! here some pics, no tuning, no performance, the good old stock cummins, im one of the rare lucky cummins destroyer lol but i have 4more trucks...
Old Jul 5, 2009 | 07:17 AM
That looks like KDP or dropped case bolt damage. Is the KDP still in its hidey-hole? Any bolts missing?
Old Jul 5, 2009 | 07:37 AM
dizzel's Avatar
That's crazy Konrad, I'm glad I didn't buy that truck off you!
No offence
Eric
Old Jul 5, 2009 | 09:44 AM
82F100SWB's Avatar
I can say I have seen just that failure before, once in a 4BT, and once in a 5.9, both were in heavy equipment. Can't say I've seen it in a pickup app before.
Old Jul 5, 2009 | 05:55 PM
J BODY's Avatar
Seems there was mention of the newer Rotella and cam shaft failures. Any chance this might back that claim up? (I still run Rotella in my 01)
....and how long has that thing been sitting? I don't have that much rust on my whole truck.
