6.2l Chevrolet wont start
I replaced the heads on a 6.2l Chevrolet and cant get it restarted. Did not remove the injector pump just the fuel lines. I know that I have fuel feeding the pump but none coming out. What is the proper way to bleed the pump on a 6.2l.
Any time I have done it its just cracking lines on the injectors and running the starter until you see some fuel coming out. You could also pull the fuel return rubber lines off to see if you are getting flow. Pumping the fuel filters full as much as you can helps a lot as well.
Just went thru this on a IDI 7.3 Furd, took way longer than I thought to get fuel from the pump to the Injectors. If it is a stick, try pull starting, if not, unhook the glow plugs and try running it one WD40.
We had already pulled the fuel line that was leaving the filter and turned it over until fuel poured out. According to some information I found the injector pump is suppose to self bleed. We tightened all the lines down and turned it over for about 45 seconds and it fired up. I knew changing the heads would be a job, but I didn't realize that it would take as long as it took us. I am glad the job is done now.
Apologize for bumping this thread up. But seemed to be similar with my dad's blazer. after a week of driving the car ended up not starting on the next morning. replaced everything, the alternator, the battery and the starter but seems no warning signs at all. then, the mechanic recommend replacing the fuel pump and works well. recommend doing the same thing. Just give it a try!
__________________________________________________
Chevrolet parts
"No truck should ever be lowerd! NEVER"
Chevrolet parts
Yeah big motors gutless too dad had one before his dodge it went through hell n back that truck did nothing but haul props n firewood for almost 20 years had over 500k km on it but heads where cracked 100k before we pulled it ran fine never smoked white just used water.
He ended up putting in a done up 4 bolt main carbed 350 in the truck sold it two years later.
04ctd
Jun 14, 2015 02:27 PM
