47RE slipping in 2nd
Old May 17, 2006 | 08:15 AM
SBishop's Avatar
Tranny has just started slipping in 2nd gear. 70K miles. Fluid good. Bands were adjusted at 30K. Fluid changes at 30K and 60K.
Doesn't slip if I put it in Manual 2nd.
Valve body? Governor Pressure Sensor?
Old May 17, 2006 | 06:06 PM
RCW's Avatar
RCW
Check your throttle position cable for proper adjustment, or either the ends being cracked or the bayonet clips on the housing being loose. Also, check your selector linkage to make sure all the bushings are present and in good condition.
I would lean toward the throttle position cable being the problem and the valve body not knowing where it is set as a result. That will cause low pressure and clutch slippage.
The other possible culprit is the APPS. Do the relearn procedure, and if that does not solve the problem, test the sensor to make sure it is working.
Old May 18, 2006 | 05:54 AM
AlpineRAM's Avatar
Definitely check the front band adjustment too! Even if it hasn't been out of whack to start with and the cause was some or the other thing that RCW mentioned the band will be worn down a good bit due to the slipping.
HTH
AlpineRAM
Old May 18, 2006 | 08:35 AM
SBishop's Avatar
RCW, AlpineRam
Thanks for the tips. Will check them out this weekend. The odd part about all this is that it happened on the way to work. Driving home after work, everything worked perfectly, also on the way to work this morning, no problems. My first thought was that some crud had gotten in the valvebody and screwed things up. Will let you know if I find anything.
Old May 18, 2006 | 09:40 AM
AlpineRAM's Avatar
If it's like that I'd start with the basics- fluid level and state (burnt-dirty etc) filter change and band adjustment. While in there you can check the linkage RCW mentioned.
Do also check for codes.
HTH
AlpineRAM
Old May 18, 2006 | 10:00 AM
SBishop's Avatar
AlpineRam,
No codes were thrown. As mentioned, fluid levels and condition is good.
Will be dropping the pan this weekend to check everything out.
Old May 18, 2006 | 10:32 AM
04ctd's Avatar
Originally Posted by RCW
APPS relearn procedure, test the sensor to make sure it is working.
can you post how to do the re-learn,
and how to test the sensor?
mine shudders in 2nd, annoys the crap out of me.
plenty of fluid, changes, filters,
dealer looked at last month, no problems found....
APD
Jul 19, 2015 08:45 AM
mopar440cu
Mar 9, 2011 11:04 AM
subdieselmech
Nov 20, 2006 04:41 PM
Munchies
Oct 19, 2006 06:09 AM
andrewsurfdude
Jul 18, 2004 06:53 PM
