47 rh troubles
Old Sep 22, 2008 | 06:09 AM
turfguy's Avatar
47 rh troubles
hey gang
swapped a tranny in my truck a few weeks ago & all was great until 2 days ago. It wants to stay in 1st or 2nd gear, esp if I manually downshift into 1st & go thru the gears, it wants to stay in 1st or 2nd. I tried shutting it off then back on while coasting, & it worked a few times but not much anymore. If I really throttle it in 1st & then let off a little, it will sometimes shift into 2nd but it really grabs 2nd like it has a shift kit. Sometimes fiddling with the OD button helps, sometmes not. I adjusted theTPS& it didn't change anything. I was thinking maybe the linkage is a little off, or would hardening seals do that?? I really need help; I have an out of state hauling trip this weekend!!! thanks guys
Old Sep 22, 2008 | 07:21 AM
1-2-3's Avatar
Just a plain ole guy
You probably need a good trans shop. When my 47 wouldn't shift into 2nd corectly, it was a broken band, which required a rebuild (might as well while your in that deep).
Old Sep 22, 2008 | 07:32 AM
turfguy's Avatar
I hope its not too bad; I just bought it off ebay & it was rebuilt less than 10k miles ago......
Old Sep 22, 2008 | 04:11 PM
dozer12216's Avatar
47RH has a mechancial governor. Sounds like governor is fubarred. No governor pressure = no upshift, unless like you say. Good news is OD unit can be removed without pullling tranny complete. Governor is in rear of OD unit. A fsm will detail a checking procedure and removal of unit.
DF5152
May 12, 2003 12:53 PM
Nicholas
Jan 11, 2003 11:09 AM
woodpecker
Dec 20, 2002 09:40 PM
nascar22
Dec 19, 2002 10:25 AM
Stevie G
Nov 5, 2002 07:56 AM
