Truck stopped running
Old 09-05-2018, 01:49 PM
Sizedog's Avatar
2007.5 dodge 3500 6.7
just driving down the road and the engine stopped ....
shut key off and tried to start ... nothing no click or anything..
checked all fuses .. all ok
all dash lights .. headlights... windows... radio ... all work ...
Tried hooking up to cheap scanner that had worked in the past .... does not recognize truck....
turned key and noticed fass fuel pump did not come on and still nothing....
Pushed truck into parking lot .... previously you could see what gear I was in on the dash (p,r,n,d) ..
then towed a block to my buddy's house ....
now there is no indication for what gear I'm in .....
Still no start or turn over or fuel pump ....
hooked up to a real scanner and it doesn't show anything out of the ordinary.....
I'm lost
hope for some help
thanks
Old 09-05-2018, 03:56 PM
Mexstan's Avatar
What is the battery voltage on the battery posts? What is the battery voltage on the terminals?
Old 09-05-2018, 04:01 PM
Sizedog's Avatar
I'll check
Old 09-06-2018, 07:01 AM
Sizedog's Avatar
Checked both batteries disconnected and was 12.1 volts each
Old 09-06-2018, 07:34 AM
Sizedog's Avatar
I noticed also that glow plug light and that lightning bolt light do not come on
Old 09-06-2018, 08:17 AM
Sizedog's Avatar
If the fuel pump stopped working would that shut down the ignition on the truck?
Old 09-06-2018, 10:32 PM
pind's Avatar
Does the security light on the dash flash continuously with the key on? If it does, try a different key., and also check the wires going to the key reader built into the key switch bezel.
Old 09-06-2018, 10:56 PM
Sizedog's Avatar
No everything is normal in that respect
Old 09-07-2018, 03:37 PM
John_P's Avatar
Sizedog:
I would recommend finding someone who has a Dodge DRB Scanner and thoroughly check the entire system on your truck. If you don't know anyone that has a Dodge DRB Scanner from a Dodge Dealer, I would check some of the independent or diesel truck shops to see if they have one. With that handheld computer, you will be able to find what is going on Sir.
John_P
Old 09-07-2018, 07:20 PM
Sizedog's Avatar
Thanks .... I wish we could go back and have vehicles that each system was on it's own and a regular person could fix things themselves
highgun
03-17-2009 12:46 PM
Tingram
10-12-2008 11:24 PM
dieselman41
04-05-2008 02:57 PM
Stainless
02-10-2008 11:45 PM
BRUISER
11-06-2007 07:39 AM
Quick Reply: Truck stopped running
