2003 Won't start
2003 Won't start
I have a 2003 3500 manual transmission. It has 60 HP injectors, Edge Juice w/ Attitude, FASS 95 gph, AFE ProGuard 7 Stage II intake and Pro-Flo 5" exhaust. Last time I started it the stereo caught on fire and I shut it down. It had blown three fuses. I took the stereo out and replaced the fuses. Now when I try to start it, the lift pump doesn't come on nor does the preheaters. On the instument cluster the voltage and fuel level guages do not show andthing. When I do the cluster check all of the guages work. When I try cycle the key three times it will not show P codes. When I did the C code check I got several codes:
27 64
29 64
81 00
A3 17
AA 00
00 00
One of these says no communication with ECU. I checked the fusable link coming off of the Integrated Power Contol Module and it is good. I don't know if the ECU is fried or I have lost communication with the clust some how. Any help would be much appreciated.
27 64
29 64
81 00
A3 17
AA 00
00 00
steffan
Jan 9, 2007 09:24 AM
