2003 1500 P2106/p2175
Old Jan 30, 2007 | 05:52 AM
Txwelder's Avatar
Anybody have a clue?
Old Jan 30, 2007 | 09:08 PM
RCW's Avatar
RCW
They are both gas engine air metering codes, likely related to the impedance of the mass airflow sensor being out of sync with the throttle position sensor. Usually this can be cleared up by spraying the intake with a throttle bore cleaner while the engine is running, then oil the bore where the butterfly clicks shut against the air body with a light gun oil such as RemOil, but keep it off the wires on the mass air flow sensor.
Be sure to drive the rig long enough that the cat gets fully heated and burns itself clean after you inject oil, or you run the risk of poisoning the cat.
Old Jan 30, 2007 | 11:25 PM
J BODY's Avatar
No mass air flow on a dodge truck.
which engine??? assuming 5.7 since it has a ETC
first code is: ETC (electronic throttle control) forced limit power
#2 is: Low air flow restriction detected
Old Jan 31, 2007 | 05:57 AM
Txwelder's Avatar
soooo, what to do to fix it. Not my truck, co worker.
Old Jan 31, 2007 | 07:49 AM
J BODY's Avatar
It could be as easy as the TPS, which if its the 5.7 it will be an APPS. I've seen ones that go on the fritz cause both of those DTC's. Of course, you can't rule out a wiring issue either. Best is to find someone handy with diag and a scan tool and let them get to work.
olddodgetrucks
Mar 14, 2010 06:00 PM
Jason_K
Jan 29, 2009 02:54 PM
Little-bit
May 25, 2006 05:20 PM
shortround
Aug 22, 2003 02:50 PM
gunracer1
Mar 14, 2003 10:26 AM
