2002 stall problem
2002 stall problem
on my 2002 3/4 ton 4x4 the truck seem to stall and the accelerator doesnt resspond. the truck smokes white and then it returns to normal. Could this be injector problems?
Checked fuel pressure on the schreodor valve on the side of the injector pump and it would idle at about 7-8 psig and when i would accelerate it would drop to as low as 2.5 to 3 psig
It's the Injection Pump. My truck had the dead pedal issue and smoked pretty bad when I stepped on the go pedal and the smoke wasn't white more of a greyish color. Had pump replaced and now have beautiful black smoke and no dead pedal. Go to your dealer have them warranty the part. You will have to pay a deductible of at least $100 dollars but it's much bettern then paying for a $1200 part.
-CM
-CM
flyingd
17
Jul 11, 2017 11:13 AM
JD730
Aug 2, 2005 11:33 AM
