2001 cutting out around 2500 rpm
Old Aug 14, 2006 | 06:56 PM
ropes's Avatar
My 2001 is cutting out & sputtering around 2500 rpm usually in third gear.It also sometimes runs as if it is governed at 1000 rpm and blows white smoke & will eventually blow out & start running ok again. Both problems are intermitten sometimes it runs fine, the cutting out happens the most. Any ideas?
Old Aug 14, 2006 | 09:31 PM
blackdiesel's Avatar
Registered
welcome to DTR. sounds like you should of found use sooner. turn the key to on (not start) then off then on and back off then onthen on, and then look at your odometer it will read the codes in your truck, It will look in you pcm and your ecm let it read bought. It sounds like you might find a p1693 and a p0216 and that won't be very good you IP is on it's way south . Go check it and get back to us.
Old Aug 14, 2006 | 09:45 PM
ropes's Avatar
You are right,codes p1693,p0216,&0523 came up. What does that mean & what is ip? Thank you for helping.
Old Aug 14, 2006 | 10:01 PM
Registered
it is your injection pump (vp44) it will have to be replaced all you can get is a rebiult for 1k if you put it on yourself, it's not as hard as it looks we have all the instructions you need. you will also need a new lift pump at around 200 to 600 depending which way you go you will need a fuel pressure gauge to monitor the new lift pump. when it fails it starves the ip and it burns up. do a search on vp44 and you will find all kinds of info that will be helpful to you. BTW if you take it to a dealer and your over the 5year 100k it will cost you ALOT MORE, sorry to be the bearer of bad news.
Old Aug 14, 2006 | 10:12 PM
ropes's Avatar
Thanks for the help. I have 89000 miles on it and this is the fifth year, so hopefully its under warranty. I will find out & if not I will contact you for your information on changing it. Thanks again.
Old Aug 14, 2006 | 10:26 PM
Registered
YOU will be one lucky man if you inservice date is less than 5 years on a 01 (it is possible) good luck and don't take no for a answer
Old Aug 14, 2006 | 10:59 PM
Registered
and if the dealer gives you any crap about the pump not being the problem, tell them you talked to a 16 year old kid on the INTERNET last night and HE said that YOU need to replace YOUR vp!
Old Aug 16, 2006 | 09:33 PM
ropes's Avatar
Well I am lucky it is under warranty, I was just wondering if you know what that third code p 0523 is?
Old Aug 16, 2006 | 10:09 PM
Registered
well i did a search on here and the only thing i can come up with is oil pressure voltage too high. hope this helps
Old Aug 17, 2006 | 10:05 AM
ropes's Avatar
Thank you for your time. You sure know your diesels, thanks. Looked at your pics, you haul hay a little different over there, pretty cool- cows are probably fat!
Old Aug 18, 2006 | 11:57 AM
Registered
where are you located?
Old Aug 22, 2006 | 08:44 AM
ropes's Avatar
In AZ. Dry desert.
klcammie
0
May 17, 2010 10:20 PM
bcool
Nov 28, 2008 04:29 PM
NHRedneck
Mar 5, 2007 02:32 PM
fishin fever
Feb 22, 2004 08:32 PM
