Missing at cutting out from Idle all the way to full throttle RPM
Old Nov 27, 2008 | 05:50 PM
bcool's Avatar
I'm collecting all my parts for my P-pump swap but in the mean time i have a 99' 24valve that is missing and cutting out at idle and all the way through the RPM and throttle range. I've even had the truck die on me while idling a couple of times. I am getting no codes whatsoever and the truck will run perfectly fine most of the time. It throws most of its missing hissy fits all at once and it drives and runs fine most of the other time. I'd like to keep my truck running until my swap as i use it for work. Is there some small common things i can check or is it just my VP giving me a sweet kiss goodbye?
Thanks
-Brendan
Old Nov 27, 2008 | 11:13 PM
Berge9798's Avatar
I had this problem with an engine i rebuilt in school. I had an injector that was bad witch was causing it to miss so i replaced that and is was doing the same thing just not as bad. and i couldn't figure out why.it ended up being i got blow by back in the fuel system from that bad injector and i had air in the fuel lines
Old Nov 28, 2008 | 04:29 PM
bcool's Avatar
Yeah this is more like someone shutting the key off and kicking it back on. Its pretty violent when i'm under load and i'm sure my transmission doesn't like being slapped around like that. It seems to have gotten worse today for some reason.
jefjsak
Jan 15, 2015 03:44 PM
Onemoparnut
Aug 19, 2013 08:11 PM
cookie monster
Feb 4, 2011 04:48 PM
Mallard
Apr 9, 2007 12:59 AM
j
Nov 14, 2003 09:38 PM
