2000 Wont Start HELP!!!
Old Nov 26, 2006 | 04:40 PM
sumner's Avatar
Question 2000 Wont Start HELP!!!
Hey all. My ol man has a 2000 that isnt starting. The weather here has gotten a little colder(Montana), around 5-10 degrees. I got in the truck, cycle the intake heaters twice and it fired after cranking a few times, and just died. I popped the hood, and noticed a leak around the filter housing. I pulled the top off and replaced the filter. Now if you cycle the heaters and try to start, it just cranks. The LP will only come on AFTER you try starting when you turn the key off. The ol man doesn't have a fp guage as of yet. Any suggestions??? I know on my 04 the lp will come on right when you turn the key to on. I checked for codes and there are none. Thanks for any help...
Old Nov 26, 2006 | 04:54 PM
RATTLINRAM's Avatar
You can try loosening the line going from the filter housing to the injection pump and see if the fuel is getting to there by running the lift pump. If it is,,, then start bleeding the injectors. It may be something as simple as air in the lines going to the injectors. The LP on my 99 acts the same way after the initial 1st time turning the key on. I have to bump the motor in order to get it to run for the 20 or so seconds. It may take bleeding at least 3 injectors before she'll fire,,,,,, it will run rough, but should smooth out.
Let us know what you find.
Old Nov 26, 2006 | 04:58 PM
mopargw's Avatar
Could be jelling as well. Try some of the PS in the red bottle. The DIESEL 911.
Old Nov 26, 2006 | 05:02 PM
sumner's Avatar
I was thinking gelling as well. The ol man uses stanadyne every fillup. Fuel that was left in the canister looked alright. The way the lift pump is acting kinda has me bothered though.... I have the truck in the garage heating up. Im about to go out again and have a look. Thank you for all the replies so far.
Old Nov 30, 2006 | 02:43 AM
catnfool's Avatar
Where in MT are you? I'm in Kalispell, just got back from the east side(-20*)
Old Nov 30, 2006 | 05:29 AM
P.J's Avatar
P.J
The LP cycling only after you "bump" the starter is totally normal. It might make a real quick blip when you turn the key "on", but it won't run until you attempt to crank.
boonewaxwell
15
Sep 7, 2015 02:55 PM
cjk2000
May 19, 2011 10:14 AM
vp_mopar
Oct 10, 2008 12:27 AM
qcstunter
Jan 9, 2007 04:10 PM
shellman
Nov 29, 2005 07:29 PM
