07' 5.9 block broken????????????
Old Sep 11, 2007 | 03:41 PM
mitchellspeed's Avatar
i have a 07' 5.9 dodge 3500 about a week ago i started having problems with my truck white smoking bad in the mornings and while driving.now the problem is still the same but the motor is slightly knocking and quivvers and it's acting like its starving for fuel... the dodge house said they cant warrenty it because it was contammanated fuel in the tank which was reg. green diesel. They said it was the block and the #1 cyclender wasent firing.
what is the problem and what do i do .
thanks
m.speed
Old Sep 11, 2007 | 05:01 PM
lastchance's Avatar
you might have a couple of bad injectors i would drain tank and put fresh fuel in it and change filters, when you change filters(fuel) put about 50/50
automatic trans fluid in it and crank it. see if that clears it up.the trans fluid will sometimes free up and lubricate the injection system.
and i dont understand why the dodge place told you that.
if that doesnt work then it is time for injectors, hopefully you havent hurt the pump yet.
Old Sep 11, 2007 | 05:08 PM
dodgezilla04's Avatar
NO TRANNY FLUID!!!!! EVER. You WILL destroy the pump and injectors. These arent 6.5 chevy diesels.
use a commercially made fuel treatment, such as stanadyne or power service.
Old Sep 11, 2007 | 05:10 PM
lastchance's Avatar
i have always used it in big trucks and never had a problem.
oh well i am sorry for that statement.
get some lucas fuel treatment i know for a fact it want hurt it!
Old Sep 11, 2007 | 05:15 PM
much better. big trucks arent running 25k psi of injection pressure. the clearances in the pumps on our trucks are so bloody tight because of the pressures they need to acheive, the atf(which had too many cleaning additives) will remove the lubrication.
Old Sep 12, 2007 | 07:27 AM
patdaly's Avatar
1.) Pull a fuel sample from the filter.
2.) Get some fuel for a sample from the place you last bought fuel.
3.) Call DC directly or your state AG and get the ball rolling.
Something is definatly WRONG here people, we have a 4 year period of common rail Cummins and now there are at least 3 on here with non-warranted engines due to "contamination"
I'm calling this fishy.....
Last edited by patdaly; Sep 12, 2007 at 06:03 PM. Reason: whoops, put 14 years instead of 4
Old Sep 12, 2007 | 12:55 PM
lastchance's Avatar
yes i will second that?
Old Sep 14, 2007 | 10:35 AM
IntakeRacing's Avatar
i'd just clean the tank out and take it to a new dealership. should be warranty then.
Old Sep 14, 2007 | 10:51 AM
Box5's Avatar
i agree with that ^. If there gonna be stuborn about fullfilling a warrenty because a fuel station had bad fuel, find a way around it like draining the tank and puting good fuel in and go back to another dealer like he said ^.
Old Sep 14, 2007 | 11:00 AM
that only works if the first dealer didnt enter the data into dc's system, they track repair claims by vin.
scottsjeeprolet's Avatar
I'm just curious about how they came to the conclusion that the fuel was bad?
Regardless the FF will trap most if not all of the crap from reaching the IP. I am seeing a new trend of the rob u ships claiming this to get out of the warranty.
Like said above get your own sample of fuel and have it tested.
Old Sep 14, 2007 | 02:53 PM
bob4x4's Avatar
With the lower micron rating of the newer fuel filters,I am told the water does not get separated as well.Chryslers feeling is that they did not put the water in your truck.Hence your dime.
I have seen many contaminated trucks get repaired by insurance,but never under warranty.
Bob
NoSparkplugs
Apr 30, 2008 11:27 PM
Rpainter
21
Mar 8, 2008 02:36 PM
24Vford
Jan 2, 2007 11:14 AM
plow
Dec 28, 2005 02:42 PM
1320
May 17, 2003 03:28 PM
