04 turbo too quiet
Old Mar 19, 2004 | 07:49 PM
20014x4's Avatar
04 turbo too quiet
The other day I was servicing a friends 04. after removing the air intake tubing and getting to the oil filter. I noticed what appears to be a baffel in a peice of 5" plastic pipe. His silencer ring fell off with a little help from my screwdriver. the turbo is still very quiet. you think if I lost that piece of 5" baffel pipe and installed 5" pipe in its place it would sing a little more? just a thought. we ordered his BHAF. straight pipe is next if he trusts me with a hack saw and welder.
Old Mar 19, 2004 | 09:51 PM
Stamey's Avatar
I dunno if they changed it for 2004, but they have a length of straight pipe on the 2003 that has supports built into it to keep the straight section from collapsing from the vacuum of the turbo. It this what you are talking about?
Chris
Old Mar 19, 2004 | 11:15 PM
infidel's Avatar
What you are seeing is straightening vanes that serve to lessen turbulent air at the turbo inlet. Some people call it the torque tube.
To remove it would make the turbo less efficient.
Old Mar 20, 2004 | 08:54 AM
nickleinonen's Avatar
Re: 04 turbo too quiet
genos sells an eliminator pipe for that piece [assuming it is the same between the 03-04.0 engines] and on them it is like 5.5", so if you can find some 5" abs pipe it'll work, but 5" exhaust pipe won't [the abs is 5" ID, exhaust pipe is 5" OD]
Oilburner04
27
Jan 24, 2020 05:41 AM
ChrisM55
28
Jan 24, 2008 10:50 PM
RyeThomas
Aug 22, 2006 11:31 PM
Strjock81
Jun 12, 2004 10:44 AM
