04-no start?
Old Apr 14, 2006 | 12:04 AM
diesel71's Avatar
04-no start?
2004 cummins no start?? run diagnostic test no codes. transfer pump is running, fuel psi to main injector pump is 10 psi. batterys are new, heater grids are working. one shot of starting fluid and she fires up. turn key off and no restart hot or cold??????
Old Apr 14, 2006 | 02:43 AM
68ss's Avatar
You may have the same problem I had and where the FUEL PRESSURE LIMITING VALVE is not letting the pressure build up in the rail manifold. If you crack a injector line and it has a fuel flow where it just rolls out the line as you crank it then I would say that its the FUEL PRESSURE LIMITING VALVE.
CoolumConst
Oct 11, 2008 10:00 PM
bfarrell
Nov 30, 2005 03:23 PM
Erik Dlux
24
Dec 8, 2004 07:26 AM
502502
Nov 27, 2004 09:15 PM
eng208
Jul 14, 2004 06:21 PM
