03 fan problems
Old Aug 19, 2009 | 07:27 PM
space411's Avatar
03 fan problems
i have a 03 dodge and the wire that go from the fan to the truck harness have been wriped apart how i dont know. but does and one know what wires do to each other on each plug. the readon i wana fix this is b/c my fan stays engauged all the time
thanks james
Old Aug 22, 2009 | 11:04 PM
RCW's Avatar
RCW
If you peel back the harness insulation you will find the wires are coded, so reconnection is a breeze.
However, if the solenoid assembly is turning with the fan and clutch and everything is locked, that assembly is shot and will need to be replaced. That will also be why the harness was torn apart. Pretty common problem.
Old Aug 23, 2009 | 06:41 PM
Bark's Avatar
I know this isnt much help but I am finally starting to use the search function. This is one of the many items I came up with when I typed in “fan wiring”
https://www.dieseltruckresource.com/...ght=fan+wiring
I was looking for a post that helped me awhile back. I am sure if I type in the correct words into search I will find it. At first I was mispelling wiring as wireing and came up with nothing.
FamilyDiesel
Mar 30, 2008 05:53 AM
jrs_dodge_diesel
Sep 28, 2007 11:38 AM
MmmDieselFumes
Sep 27, 2007 06:44 PM
MmmDieselFumes
Sep 27, 2007 03:04 PM
big jimmy
Jul 7, 2006 01:33 PM
