01 wont start
Old Dec 5, 2005 | 10:51 AM
workinman's Avatar
01 wont start
have an 01 24v was running fine then hiccuped twice. stopped and killed it then it wouldn,t start.drained filter got it started and air bled out but it died at next corner(when i let off pedal to stop).shook really bad whem i tried to start it.got it home bled lines got it started again but it surges when idling. no codes showing. 14lbs. fuel pressure. please help
Old Dec 5, 2005 | 12:00 PM
j-fox's Avatar
How did you retrieve the codes? I bet there is some.
Cycle the key 3 times , do not start it and leave it in the on position. Watch the odometer for codes and wait till the miles come back up.
Old Dec 5, 2005 | 12:34 PM
workinman's Avatar
i have an obd2 code reader. the truck is stock and doesn't surge until it gets warmed up.
Old Dec 5, 2005 | 12:39 PM
Geico266's Avatar
Did you get any codes?
Old Dec 5, 2005 | 01:45 PM
workinman's Avatar
no codes showing up
Old Dec 5, 2005 | 06:53 PM
phox_mulder's Avatar
You don't have a location listed to guage the temps there,
but did you check the filter to see if you had a gelling or other obstruction problem?
phox
Old Dec 5, 2005 | 09:12 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Is it possible that you got gas? when was the last time you filled up?
Old Dec 5, 2005 | 09:34 PM
drew03's Avatar
my girlfriend's 01 did the same thing only it would not restart. the gauge said 1/4 of a tank. it died going up hill when it had only a gallon in it. your gauge may also not be working properly.
Old Dec 5, 2005 | 10:08 PM
workinman's Avatar
had to replce the pickup unit in tank screen was clogged. put in 44k and filled it up with fuel and still has problem. dealers no help in central oklahoma
Old Dec 11, 2005 | 07:58 PM
JW3's Avatar
JW3
same happened on my 2000
same happenend on my 2000 with no mods the dealer was a real jerk but had to figure it out for myself it was a crank position sensor hope it helps
rustydeeretech
Jun 16, 2010 09:41 AM
CoolumConst
Oct 11, 2008 10:00 PM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
Desert Diesel
Dec 5, 2002 08:53 PM
