01 knock noice and white smoke
Old 01-29-2009, 05:36 AM
1stGen72's Avatar
Not sure if this would be a wrist pin, piston, injector, rod bearing, maybe broked valve springs? The truck is stock auto was pulling hill no traier and started doing this any one have any ideas
Old 01-29-2009, 05:52 AM
67HotRod's Avatar
Did you check for any codes?
Old 01-29-2009, 06:38 AM
Redliner's Avatar
First check codes. Almost sounds like you dropped an injector. Second I would pull the injectors to see what they look like.
Old 01-29-2009, 07:10 AM
RCW
RCW's Avatar
Knocking and white smoke is likely a failed injector, however it could be a broken piston, cracked head, or blown headgasket.
Do not drive it until you have completed diagnostics, then let it idle and listen to each exhaust manifold runner with a stethoscope. If you hear a wheezing, shut it down and do a compression test on the wheezing cylinder.
If you catch a broken or burned piston early enough that cylinder generally can be saved.
If there is no wheezing but simply a loud knock at one cylinder, then pull that injector on the noisy cylinder and check the tip. If that is the problem it is a simple and relatively inexpensive test. If the tip is good, then check the compression, you need to go through the injector hole anyway!
The other common issue with 24 valves is cracking of the head between the exhaust valves. That normally will allow compression to blow into the cooling system, and you will see bubbles in the radiator filler.
Old 01-29-2009, 12:24 PM
1stGen72's Avatar
I did not check yet. But that my project for the weekend, we will have to see what happens? Thanks alot for the info i will try it all.
Zee
03-23-2010 09:54 PM
1stGen72
02-02-2009 11:51 PM
1BAD4X4
06-01-2008 10:37 PM
HappyGA
15
10-16-2006 08:21 AM
Hoss
30
10-03-2006 02:57 PM
Quick Reply: 01 knock noice and white smoke
