*** valve body?
Old Aug 29, 2008 | 08:51 PM
jaswright2003's Avatar
*** valve body?
I had to take the valve body out of the "built transmission" I bought, and change the wiring. Why would they only put 8 bolts back in instead of 10 to hold the valve body in place? Do I need to take the other 2 out of my stock one?
Old Aug 29, 2008 | 09:04 PM
j-fox's Avatar
Yes you need all of them.
Old Aug 29, 2008 | 09:14 PM
Thats what i thought. You pay $6500+ for a billet transmission and they forget to put some bolts back in it. I sure hope there are billet shafts in there.
Old Aug 30, 2008 | 03:56 AM
dozer12216's Avatar
Not only are all bolts required but must be torqued correctlly.
Old Sep 4, 2008 | 04:18 PM
I got it back going saturday morning everything was fine. Saturday-Wednesdayno problem. I go out today to go to work start my truck and go back inside, 5-10 minutes later I come get in put it in reverse nothing. After playing with it for a little bit I decide to cut the truck off and try to start in while in gear. It does not start in R, D, 2, 1, and only starts in P and N like it should. I start it back up put it in reverse (you can feel it catch just a little) nothing. If I give it a lot of throttle (2500+rpm) it will start to move. Any idea's?
Old Sep 4, 2008 | 09:47 PM
oldblues's Avatar
fluid level ?
might have sprung a leek !
Old Sep 5, 2008 | 03:50 PM
HTS said they will replace the transmission.
Old Sep 5, 2008 | 03:54 PM
j-fox's Avatar
It sounds like it needs a will!!!!
Anyone can make a mistake, and overlook a bolt But two is sloppy. That is one area that is very critical, hence the need to torque them.
You should of gone to them first, not here.
Old Sep 5, 2008 | 04:00 PM
I did, and they kept telling me to try different things. If it had the right sensors in it to start with I would have never known the bolts were missing.
Old Sep 5, 2008 | 05:31 PM
j-fox's Avatar
Ok, good catch, you save a trans.
Was the wiring harness from an earlier year?
Did you get it going?
Old Sep 5, 2008 | 07:51 PM
The wiring harness and the one sensor was for a 00-02.
Trooperthorn
Jan 7, 2011 12:55 AM
jj3500
Jul 12, 2009 03:59 PM
12ValverDave
Nov 15, 2008 03:50 PM
Luke S
Nov 30, 2002 10:57 AM
