How/where to grease front axle on 2010 2500.
Old Oct 10, 2010 | 02:13 PM
jnovak's Avatar
Under the hood of my 2010 Laramie 2500, there is a sticker which says "CAUTION: Grease front axle with every oil change" and it shows a diagram of the u-joints next to the transfer case. But, for the life of me, I can not find any grease zerks on or near the u-joints. In fact, after looking at the front end and all of the u-joints (front axle, front wheels, rear axle), I do not see any grease zerks.
I grew up on a farm and am accustomed to the "nipple" type grease zerks. So, maybe there is a newer type of grease zerk....
Could somebody tell me where to look and what to look for?
Old Oct 10, 2010 | 02:31 PM
DirtEater's Avatar
The front axle doesn't have a zerk for 2010. The front drive shaft has a needle type grease fitting and you needle one of those needles for your grease gun.
Here's a pic of the needle fitting you need and a pic of the drive shaft lube point that someone else posted awhile back. Very useful pic and I printed it out on a color printer for future reference.
Attached Thumbnails How/where to grease front axle on 2010 2500.-needle.jpg   How/where to grease front axle on 2010 2500.-063500frontdriveshaftlubepoint.jpg
Old Oct 11, 2010 | 08:37 AM
jnovak's Avatar
Thank you!
Old Oct 12, 2010 | 05:24 PM
dmurdock's Avatar
Is it just one u-joint that needs greased or all of them on the front axle assembly? (I'm assuming you need one wheel off the ground to accomplish this)
Old Oct 12, 2010 | 08:35 PM
DodgeChallenger's Avatar
Just the constant velocity joint as per the picture posted. When you replace U-Joints then it is suggested to get the greasable ones. The drawback with greasable units is that most people kill them with kindness - IE they place too much gease in them usually and blow the seals.
Old Oct 16, 2010 | 05:54 PM
05stram's Avatar
where does one buy the needle to grease I check autozone and advance auto neither had it
Old Oct 17, 2010 | 10:38 AM
DirtEater's Avatar
I've seen the needle fittings at all of the major parts stores including the ones you mentioned. They are a common item and sometimes will have 3 or 4 different types.
Old Oct 17, 2010 | 09:13 PM
05stram's Avatar
here they are a bunch of idiots I found one today at NAPA - the guy at NAPA laughed when I told him the other two did not have it. He said he was suprised they had anything considering they do not stock their shelves correctly
Old Oct 23, 2010 | 08:18 PM
Monkey 456's Avatar
I have never seen a fitting like that before. How dose that connect to the grease gun and do you just press it on the lube point? I have one of the needle fittings and did not seem to work very well.
Old Oct 23, 2010 | 08:25 PM
picdodge's Avatar
You got it. Jack up one wheel and rotate the DS until you find the "zerk" and then press the neddle in and pump . Its a bugger to get lined up and I usually waste a lot grease trying to get it lined up straight.
twincam2000
Sep 6, 2011 04:14 PM
cwhowe3
0
Aug 30, 2011 08:50 AM
HOHN
Big Rigs
27
Sep 21, 2009 07:03 PM
littlebuddie
Aug 1, 2009 04:55 PM
Forty-Two
Oct 22, 2008 11:55 PM
