Getrag360 Rebuild Data
Old Mar 2, 2010 | 01:00 PM
sgreen3's Avatar
Here are some exploded parts brake downs, and touque specs for our trannys, Hope everyone can get some use out of them.
Drain Plug- 35Ft. Lbs
Front Bearing Retainer Bolt(Besure to use Blue loctite)- 22Ft. Lbs
Idler Gear Shaft Bolt- 40Ft. Lbs
Oil Fill Plug- 35Ft. Lbs
Rear Bearing Retainer Bolt(Besure to use Blue loctite)- 22Ft. Lbs
Shift Cover Bolt(Besure to use Blue loctite)- 22Ft. Lbs
Yoke Nut- 280Ft. Lbs
Old Mar 2, 2010 | 01:02 PM
sgreen3's Avatar
This figure is showing you how to measure Bearing Race Protrusion
Old Mar 2, 2010 | 01:04 PM
sgreen3's Avatar
This figure is showing you how to Measur Bearing Shim Bores
Old Mar 2, 2010 | 01:07 PM
sgreen3's Avatar
Ill try and get Re-assembly procedure posted on here tonight or tomarrow
Old Mar 2, 2010 | 04:43 PM
W150CTDproject's Avatar
got anything on rail housing or detents? 1st and 3rd gear pop out under decel unless i hold them in. im thinkin a messed up detent.
Thanks!
Old Mar 3, 2010 | 07:41 AM
sgreen3's Avatar
Well cant figure out how to get my txt document to a pdf, so if ne one needs the reassembly procedure I can e-mail it to you
Old Feb 11, 2015 | 09:40 AM
BILTIT's Avatar
See this page for a rebuild manual in .pdf.
GETRAG G360 5 Speed
nicolezeltov
Mar 10, 2013 12:23 AM
csa
Apr 2, 2011 09:14 AM
CaledoniaOutlaw
May 31, 2008 07:11 AM
nightwing695
Apr 12, 2005 08:56 PM
