Sponsored by:
Sponsored by: CARiD
Who drives this truck?
Old May 25, 2006 | 02:24 PM
  #31
ds1rider's Avatar
Think he means the top on on this page.
Old May 25, 2006 | 02:33 PM
  #32
CTD NUT's Avatar
Originally Posted by chadwick
i have seen rockwells with brakes on the ends of the axle it is just that they are drums and they are huge the wheels you would need would be a wierd size. they make disc brake conversions but they are very pricy. I always thought what if you blow out you gears no brakes or what
A stock 2.5 ton Rockwell axle assembly from a military application (the most common application) does not come equipped with pinion mounted disc brakes but rather hub mounted drums. The pinion mounted brakes work very well for trail use but are absolutely terrible for on road and/or high speed and heavily load use for two reasons.......the braking force is excellent (beacuase of the 6.72 multiplication factor) but fade and heat build up occurs VERY quickly at speed because the rotor rpm is far too high for the amount of brake surface area - there is only one rotor and caliper per axle.......and the pinion mounted brakes are very hard on pinion bearings - pinion bearing life is definitely cut way down as a result of this very high additional loading.
Pinion brakes are the way to go for a light trail rig but not when the Rockwell axle is used for it's intended application.
That said, some 5 ton axle applications appear to be OEM equipped with pinion brakes.
Old May 25, 2006 | 03:41 PM
  #33
derek840378's Avatar
Originally Posted by yarddog
Are you talking about the s-10? It has one, look closer. I couldn't find a pic that shows the rear pinion angle. Unless you guys are looking at different pics than I am.
the top ford
Old May 25, 2006 | 03:52 PM
  #34
CrashCade's Avatar
They are axle breaks also, they are used in conjustion with the front discs to help slow that beast!
Originally Posted by VikingDiesel
can anyone explain the brakes on the front on that S-10?
Old May 25, 2006 | 03:55 PM
  #35
maybe, but usually it one or the other. pinion or wheel
Old Jun 1, 2006 | 03:51 PM
  #36
mikmaze's Avatar
OK, I spotted someone today, had to be one of us,..... blue 2nd gen banks tags and team torque powerlifting on the tailgate, is that timberman's truck??? spotted in Cedar Grove NJ....... nice truck !
Totallyrad
Dec 9, 2012 12:09 AM
DWK
24
Feb 20, 2009 08:51 PM
wcbcruzer
Apr 28, 2007 12:14 PM
Dave88LX
35
Dec 7, 2006 05:49 PM
dvp98.5
Feb 5, 2004 06:10 PM
