Sponsored by:
Sponsored by: CARiD
Who drives this truck?
Old May 21, 2006 | 01:22 PM
Timmay2's Avatar
As if we dont see enough of em driving around
Old May 21, 2006 | 03:00 PM
H2SRDMB's Avatar
Originally Posted by one54ton
I love to see useless Fords.
i was just thinking about this.. and i do have to say. i dont see too many overly lifted dodges.. and i cant even remember seeing 1 at all. i may be wrong. but there must be somthing in the water that says buy a ford, lift it to the sky, then drive like a jerk and rollit and die!
Old May 23, 2006 | 12:07 AM
spunbearing's Avatar
Originally Posted by VikingDiesel
ok, this is just stupid:
Geez that's ugly. Check out the size of those airbags. He needs some 60 inch rims for that rig.
Old May 23, 2006 | 12:09 AM
can anyone explain the brakes on the front on that S-10?
That's how they've been braking those monster trucks for years. I remember seeing the disk brake on the axles back 15+ years ago.
Old May 23, 2006 | 02:37 AM
VikingDiesel's Avatar
so it had 5 brakes then? Why tho?
Old May 23, 2006 | 06:32 AM
JD730's Avatar
No, they need a set of 38's, 18.4-38's. Tractor tire of course, would make it more useless than it already is.
Old May 23, 2006 | 06:52 AM
displacedtexan's Avatar
If they are using the stock rockwell brakes, it just has two. one on each of the differentials. That way the braking force is multiplied by the gearing as well. helps with huge tires. Most of the Rockwell axles were not made with brakes on the ends like most others.
Old May 23, 2006 | 06:53 AM
fiveology's Avatar
No, just two brakes, one on the front pinion, one on the rear. Mounting the brake on the pinion lets the gear reduction of the ring and pinion help slow the truck.
Old May 23, 2006 | 06:54 AM
fiveology's Avatar
D.T. beat me to it.
Old May 23, 2006 | 07:39 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Also reduces the weight hanging at the end of the axles.
Old May 23, 2006 | 07:56 AM
PanteraGSTK's Avatar
On the monster trucks you can look at the rotor when they are stopping and it is red hot. I'm supprised they don't melt.
Old May 23, 2006 | 07:38 PM
chadwick's Avatar
i have seen rockwells with brakes on the ends of the axle it is just that they are drums and they are huge the wheels you would need would be a wierd size. they make disc brake conversions but they are very pricy. I always thought what if you blow out you gears no brakes or what
Old May 23, 2006 | 08:38 PM
jeepsuck's Avatar
ROFL!!!
Old May 23, 2006 | 08:56 PM
The parking brake set-up on my land rover and on my step-van have a drum brake mounted on the back of the transmission. When you brake it brakes all 4 wheels at the same time through the driveshaft.
Old May 25, 2006 | 02:14 PM
yarddog's Avatar
Originally Posted by masonic-dodge
The top one doesn't even have a front driveshaft
CRIS
Are you talking about the s-10? It has one, look closer. I couldn't find a pic that shows the rear pinion angle. Unless you guys are looking at different pics than I am.
