Sponsored by:
Sponsored by: CARiD
Who drives this truck?
Old May 20, 2006 | 08:36 PM
doomgaze's Avatar
Just wondering whose truck this is?
http://mrrottndog.smugmug.com/gallery/119980/7/4309479
First lifted dually I have ever liked. I wouldn't mind doing something similar to mine and I would like to ask the guy about it.
Old May 20, 2006 | 08:41 PM
merrillr4's Avatar
Sorry I dont have an answer for you, but I like it a lot!!
Old May 20, 2006 | 08:53 PM
Andy505's Avatar
I dont know either....but that is one sweet looking truck!!!
Old May 20, 2006 | 09:05 PM
VikingDiesel's Avatar
huh???
Old May 20, 2006 | 09:12 PM
ok, this is just stupid:
Old May 20, 2006 | 09:57 PM
TxDiesel007's Avatar
Im so sure
that the second one in the pic has ALOT of power... at least the top one of those fords is properly engined..... What can u do with a truck thats lifted that high? Useless... overkill if u ask me
rick
Old May 20, 2006 | 10:05 PM
masonic-dodge's Avatar
The top one doesn't even have a front driveshaft
CRIS
Old May 20, 2006 | 10:12 PM
can anyone explain the brakes on the front on that S-10?
Old May 20, 2006 | 10:31 PM
doomgaze's Avatar
I'd just like to find out what size lift/tires the guy is running on the Dodge. That is the perfect lift set up in my opinion.
Old May 20, 2006 | 11:02 PM
Mglass1045's Avatar
The S10 is running 2.5 ton rockwell axles. They probably ditched the brakes and went with a pinion mounted disk brake. Or that could be set up for a parking brake, I've seen both. I used to live out in CA and it was all to common to see big trucks like that. I think their version of off roading is parking on the grass. Those air bags on the first ford are hugh!! Looks like a kelderman setup on steriods
Old May 20, 2006 | 11:17 PM
ftltmp's Avatar
Originally Posted by TxDiesel007
Im so sure
rick
I have never understood why they raise them up that high, and their axels aint that much higher than stock.
Old May 20, 2006 | 11:18 PM
Deezle98's Avatar
Um as for that first red doge I belive it was a user on here, i think he had a video of it but i think his had stacks.
Old May 21, 2006 | 01:44 AM
derek840378's Avatar
CRIS
and the rear pinion angle is WAY off
Old May 21, 2006 | 02:28 AM
DmaxEter's Avatar
They just air the bags way up to lift the truck so its easier to show off the custom suspensions and sub frames they have built. They drop the bags down when they are rollin. Kinda like a reverse low rider setup. Instead of slaming the truck to the ground, they raise it way up when they park.
Old May 21, 2006 | 11:49 AM
one54ton's Avatar
I love to see useless Fords.
