Sponsored by:
Sponsored by: CARiD
Where to find Reman or rebuilt Cummins complete motors?
Old Apr 10, 2006 | 03:09 PM
Bosshawg600's Avatar
Well I have to get my motor rebuilt but I was told that it would be cheeper to buy a reman or rebuilt motor and then build that up. My problem is that i cannot find one. I did find some take outs from Busses but those are run hard. Can I get them from the Cummins plant or is there a company out there have some in stock? It doesnt matter if it is built up or stock I just need a new motor.
Old Apr 10, 2006 | 03:43 PM
derek840378's Avatar
ebay or try a local autoparts store. they may have some 12v's
Old Apr 10, 2006 | 03:59 PM
herb's Avatar
Been looking hard myself for a week or so. Found some new common rail engines with GOOD prices but hard to find the second generations. i seen several 12v on ebay
Old Apr 10, 2006 | 04:05 PM
CTD2001's Avatar
May i ask why you have to get a new motor, i thought that you blew the headgasket on your truck? Did you just purchase this truck? Anyway, that is a big time bummer, but you will get it back running again and all will be good.
Old Apr 10, 2006 | 04:06 PM
i think he said one time 5 of his cylinders were scored. am i correct?
Old Apr 10, 2006 | 04:07 PM
CTD2001's Avatar
I think that was Bobcat something or other that had scored cylinders
Old Apr 10, 2006 | 04:18 PM
Willy91's Avatar
I think they both have scored cyliders and piston.
Old Apr 10, 2006 | 06:17 PM
TRAVIST's Avatar
Probably not what you want to hear but you can get one through your Dodge dealer. They are a complete engine assembly right down to the oil filter. Problem is that list on them is about $15000.00. If your just looking for a short block you can pick that up for about $6000.00. Just a little info fwi.
Travist
Old Apr 10, 2006 | 07:40 PM
P Kennedy's Avatar
Cummins Dealer ???????? Cummins Reman program. Is the block hooped and can't be re-bored, a lot cheaper to put in 6 pistons and some machine work with a fresh set of bearings. PK
Old Apr 10, 2006 | 08:21 PM
Ya I have 3 scored so far and they havent even taken the engine apart yet so there might be more. Kent Crowder is working on it and he said it might be easier to buy a reman and put in some of the parts i have. The might rebuild but it depends on how bad the engine is when its completly apart. They are going to see how deep the cuts are and it might need new sleeves. Not sure of the extend of the damagee but the most it will cost is 8k and that includes a hx-35 for 1k . I want to keep internals stock but stud and fire ring the head and install 60# springs, 4k GSK, 370 injectors and what else? Already have fuel plate and #4 cam plate.
Oh and I did only drive it 149 miles when the head gasket blew. Thats when they found all the internal damage. So we are taking the PO to court for Fraud cuz he said the engine was new. There is no way I or the 3k miles he said were on it would do this much damage. I guess its up to the judge to decide.
Old Apr 10, 2006 | 08:33 PM
CTD2001's Avatar
Yeah, that is a bummer, finally got a truck that you were looking forward and the guy that sold it to you lied to your face about the motor. Well hopefully you can get some money back to have the motor fixed
Old Apr 10, 2006 | 09:21 PM
kandgo's Avatar
PM me on info on rebuilt and dyno tested 12v's as complete as you need them, I had my hand slapped once. Goodluck,,,Rick
Old Apr 11, 2006 | 11:25 PM
jaconst's Avatar
you can try fordcummins.com
Old Apr 12, 2006 | 09:44 AM
Grey Wolf's Avatar
If you don't want to have it rebuilt, you could look into a Cummins Recon engine...
http://www.cmspower.com/PowerMasters/PowerMasters.asp
http://www.cummins.com/na/pages/en/p..._Short_Blocks_
Old Apr 12, 2006 | 09:48 AM
all they have are 24v's im sure he wants to keep his 12er
