Sponsored by:
Sponsored by: CARiD
What if Dodge and Cummins separated?
Old Feb 16, 2004 | 11:10 PM
  #31
Dr. Evil's Avatar
Originally posted by induchman
After I wear out this 24v engine, I've got two 12v engines in storage to go .
Too bad you're gonna need 7 dodges to wear out those 3 engines....
Old Feb 17, 2004 | 07:59 AM
  #32
J BODY's Avatar
If you had to deal with all the failed Dana's in the Jeep line you probably wouldn't re-up a contract with them either.
Old Feb 17, 2004 | 10:57 AM
  #33
Hired Gun's Avatar
John Deere!
I had lots of trouble with my cummins in its end so I bought the Duramax. I love it. Major reason to switch was no true crew cab, not a very nice cab such as interior, or options. Lastly, I wanted a stout automatic. If dodge would change those things, I would have bought another and took my chances one more time.
But Deere!!!!
Case IH!!!!!!!!
Old Feb 17, 2004 | 06:44 PM
  #34
Jeremy Cusick's Avatar
I hate to burst your bubble, but alot of the Case/IH engines are Cummins or consolidated diesel (a Cummins subsidiary).
Deere used to make a drop in for pickup trucks. They may still.
Old Feb 17, 2004 | 07:11 PM
  #35
The Cat C7 would be nice, but think about how much you'd be paying for that nameplate on it. I love Cat engines, but for the money I don't think a Cummins could be beat.
John deere has an industrial engine that would fill the bill:
PERFORMANCE DATA
Rated Power
Intermittent 185 hp (138 kW) @ 2400 rpm
Continuous 166 hp (124 kW) @ 2400 rpm
Peak Torque
Intermittent-Rotary Pump 484 lb-ft (656 N.m) @ 1400 rpm
Intermittent-Inline Pump 503 lb-ft (682 N.m) @ 1400 rpm
Fuel Economy
BSFC-Rotary Pump 0.368 lb/hp-hr (224 g/kWh) @ 2400 rpm
BSFC-Inline Pump 0.380 lb/hp-hr (231 g/kWh) @ 2400 rpm
GENERAL DATA
Bore and Stroke - in. (mm) 4.19 x 5.00 (106 x 127)
Compression Ratio 17.0:1
Aspiration Turbocharged
Length - in. (mm) 43.9 (1116)
Width - in. (mm) 24.5 (623)
Height - in. (mm) 39.9 (1012)
Weight-Rotary Pump (Dry) - lb. (kg) 1212 (551)
Weight-Inline Pump (Dry) - lb. (kg) 1252 (569)
1stgenatheart
Oct 19, 2009 06:33 AM
wreedCTD
27
Sep 30, 2007 09:52 PM
ProjectM880
Dec 1, 2004 06:40 PM
GO 4LO
Feb 16, 2004 09:45 AM
jahluvdiesel
Dec 26, 2002 01:15 AM
