Sponsored by:
Sponsored by: CARiD
using GM gas tanks ????
Old Jul 24, 2006 | 02:56 AM
tacoma's Avatar
so I"m finally freed up enough to get to my Cummins swap, into my 87 Chevy K30, and I need to know:
Is there any reason I CAN"T use the stock tanks, assuming I drain them properly??? what to do about the in-tank pumps since the Cummins has the mech. pump? gut them???
anyway I'm excited ******, I"ve been waiting nearly 2mos to get into this, and I'll post pics somewhere.
thanks in advance for the help I'm gonna need! LOL
edit by admin
Old Jul 24, 2006 | 09:23 AM
Begle1's Avatar
I can't think of any reason why you couldn't use a Chevy gas tank.
Since we have the mechanical lift pump on the side of the block anyways, I don't think that an in-tank lift pump would be anything but a liability. So I'd take those out or just bypass them.
Old Jul 24, 2006 | 12:50 PM
tacoma's Avatar
sweet, that's about what I figured.
Old Jul 24, 2006 | 02:18 PM
Txwelder's Avatar
Does that particular truck have a narrow filler neck so as not to be able to get a diesel pump nozzle into it? Just a thought? Might have to change that.
Old Jul 24, 2006 | 05:06 PM
tacoma's Avatar
eh! Good thinking! I hadn't thought about that. Good idea!
Old Jul 24, 2006 | 05:24 PM
Begle1's Avatar
How exactly do you change that? My second filler door has that problem...
Old Jul 24, 2006 | 05:49 PM
catmandoo's Avatar
hammer and a chisel!they actually come out pretty easy.
Old Jul 24, 2006 | 07:15 PM
tacoma's Avatar
on Chevy's you can unbolt the filler neck from the body, and undo the hose. I will probably just bend up a new sheetmetal funnel and ghettofab it on, rather than making some kind of step down hose adapter to the tank.
Old Jul 25, 2006 | 07:10 AM
Txwelder's Avatar
Or you could just find a truck of the same year that had a diesel engine and rob the filler neck, should bolt up to the tank.
Old Jul 25, 2006 | 07:47 AM
htgreen3's Avatar
Just be sure the gas tank is galvanized metal. Diesel will leach out ? (not sure what compound) and is hard on the fuel system. I heard of this problem with galvanized funnels and farm tractors.
ClassA4x4
Nov 20, 2010 01:19 PM
THURENfab.
Aug 8, 2007 07:02 AM
Scovo1
30
May 11, 2007 01:08 PM
ocsurf16
Sep 25, 2006 10:36 AM
04ctd
15
Apr 30, 2006 08:45 AM
