Gas/diesel tanks, what's the difference
Old Nov 19, 2010 | 08:52 PM
ClassA4x4's Avatar
I'm swapping a Cummins into my gas-powered Class A motorhome. Can I use the 50-gallon gas tank for diesel?
Old Nov 19, 2010 | 09:06 PM
simplysmn's Avatar
Yes there is no reason why if it has a intank pump you may have to change it
Old Nov 20, 2010 | 07:59 AM
ClassA4x4's Avatar
The motorhome has no in-tank pump, the fuel pump is all mechanical. But wouldn't a low pressure inline/in-tank pump be helpful to the Cummins?
Old Nov 20, 2010 | 01:19 PM
MrExtreme's Avatar
You will want to drop the tank and remove the strainer sock from the end of the feed tube. I had a problem with that and could not figure why fuel would not feed, I guess that strainer is too fine to flow diesel well.
gts95
14
Jul 28, 2009 12:31 PM
Mcc2430
Nov 1, 2007 05:53 PM
ocsurf16
Sep 25, 2006 10:36 AM
tacoma
Jul 25, 2006 07:47 AM
