Sponsored by:
Sponsored by: CARiD
Transmission cooling lines - what choices do I have?
Old Nov 28, 2007 | 09:02 AM
5.9Excursion's Avatar
What choices do I have for the transmission cooling lines on a 3rd gen dodge. I had to modify the factory dodge lines for my Excursion cummins swap and I'm not satisfied with how they turned out (will work for now but not longterm).
Anyone ever replace your stock lines with something else? Like hydraulic hose with JIC fittings?
It appears as though JIC fittings will work on the tranny and the cooler mounting on the block. However, the cooler up front uses two short 1' hoses with quick connects before going to the hard line. I don't know how I would adapt to these?
Any ideas?
Old Nov 28, 2007 | 01:30 PM
Buckshotram's Avatar
I currently have a hydraulic hose with the fittings pressed on from my local carquest cost like $42. I have all the anodized fittings and ss braided lines from jegs waiting to be installed. Do a search for Stainless Steel Braided lines I believe joefarmer did the writeup. Ive had 3factory lines crack at the flare and have not had any trouble at all out of the hydraulic hose.
Old Nov 28, 2007 | 04:36 PM
JKM's Avatar
JKM
I too went to hydraulic hose, not a problem since then. Joefarmer did a very good writeup , but i think his handle is different now.
Old Nov 28, 2007 | 05:38 PM
WVAussie's Avatar
I used the stainless braided teflon hose mentioned and really like the way it turned out. Both these places have all the fitting you would need, compare prices between the two and you can save a good bit. The supergem fittings are really nice and easy to work with. For the cooler up front I cut the factory ends off and used a http://www.discounthydraulichose.com/product_p/419.htm and a http://www.discounthydraulichose.com/product_p/318.htm to turn a JIC fitting into a compresssion fitting then everything is JIC.
http://www.murdockindustrial.com/
Old Nov 28, 2007 | 06:47 PM
WVAussie, you linked two of the same part... Which part goes with the covert-a-flare tube sleeve?
Thanks for all the info guys...
Old Nov 29, 2007 | 06:28 AM
WVAussie's Avatar
Fixed the link. Sorry about that. Use with a JIC nipple for the compression one side and a Supergem female on the hose.
Old Nov 29, 2007 | 08:42 AM
WVAussie, I'm still alittle confused...
Did you really mean to link 418 and 419?
http://www.discounthydraulichose.com...e=418&CartID=0
http://www.discounthydraulichose.com...e=419&CartID=0
It appears that the 418 would go onto the 1/2" tube first, then the 419 and then a 1/2" male JIC fitting would than attach to them? So the 419 gets squeezed between and would compress the 1/2" tube? Is that right?
Thanks
Old Nov 29, 2007 | 10:54 AM
Would this fitting from JEGS do the same thing?
https://www.jegs.com/webapp/wcs/stor...10002_96138_-1
Old Nov 29, 2007 | 12:43 PM
WVAussie's Avatar
That is how it works, tapered end of the sleeve away from the JIC male. The Jegs piece looks like it will do the same thing.
Old Nov 29, 2007 | 12:46 PM
I guess I'll have to get some ordered. Thanks...
Rushman
13
May 28, 2012 04:24 PM
trapperff
Jan 29, 2007 07:55 PM
lil jim
Apr 8, 2005 03:40 PM
mopar2ya
Apr 1, 2004 06:42 AM
