Thoughts on this truck?
Found an 01 2nd gen 2500, 239k miles. Transmission was rebuild at 179k with receipt.
Dude wants 10800 for it. Only a few negative things, and they're relatively minor. Driver side window does not work, small seat tear on driver side, and biggest is the thing wants to pull left. A LOT. Seems like the 3 inch lift put on it was done poorly, hopefully just an alignment problem.
Mechanically in tune. Transmission shifts fine (automatic), no blow by, No strange engine noises. Squeaks a little bit when you shut it off is the only thing I noticed. The bed is pretty banged up, but the thing is 15 years old. It's a deep grey color, clear coat is holding up, no sun damage really.
I'm skeptical of the 239k. I realize these 24V diesels will run forever if they've been maintained properly, but at 239k I'm a little less worried about the engine, and more about chassis. From the test drive, nothing really grabbed my attention negatively besides that pull.
Would any of you buy it?
I don't think I would at that price without a competent mechanic looking it over very closely. I'm just a stickler that way, though.
When a lift is installed poorly, it can adversely affect wear and tear much more severely than a properly installed one (they all do, no two ways about it). Everything from barely able to be aligned to bad steering issues to bent springs. Not worth it, to me, to buy someone else's problem.
Also, another topic (won't make a new thread).
I found a beautiful 2000 with 120k miles on it. 15500 (which is a steal in this part of California). Good condition, drove flawlessly, no blow by, no strange noises, etc. But, about 3284 red flags arose.
I pull up to this dude's house. not Carl's Jr or Starbucks, not the corner of Sunset and 34th, not a Walmart, his house. I was initially expecting Bob, a 54 year old man who took his horses to the park every Saturday halfway across the states. Bob loves his truck but is upgrading to a 4th gen soon and is using this as a down payment.
But I didn't get Bob. I got an 18 year old Russian kid with a handful of cars in his driveway, no trailers, no other diesels. It seems terribly illogical to buy a Dodge 2500 diesel with practically no miles on it and drive it to school down the street with a 16 lb load. At that point, I would buy a Vespa or a Huffy bicycle with a toddler trailer.
I asked him how long he had owned it, and he responds with "a long time." Well okay. Later on he says he has only put about 3k miles on it. Must have owned it for a real long time, man. I do that in about a week and a half.
My gut feeling says "oh, this guy and his brother probably turn cars." My reproductive organs say "I need this truck in my bed today." But overall, I sense something fishier than a group of strippers from the Fuzzy Hole.
What do you guys think? He literally is desperate to sell it, told him I only have 10k not 15 (I don't) and he says he is willing to split payments up. I don't like it.
Usually your gut instinct is right, however
Could be anything...
A rebuild from a couple wrecked trucks,
Truck with a lien on it,
Stolen,
Mexican drug truck that made it across the line...
"Bob" trusts the kid to sell his truck (or his widow)...
Or simply straight up desperate to sell.
Check it out carefully. Ask buddy if you can take the VIN to the cops and watch his response. check if it has a clean title etc. etc..
Go over the truck with a fine tooth comb to look for things that simply aren't "right" (paint, signs of recent wrenching. Do the body bolts show signs of recent wrenching.
Be sure to take a buddy with you to watch your back and look for things you don't see.
Don't be in a hurry!!! if the truck goes to someone else, oh well...
Stolen,
I panic if my truck doesn't chirp when I shut it off! I concur that you should be very, very cautious if you explore the "Bob" truck any further. To me it sounds pretty sketch and I think that your gut it telling you true.
Good Luck with your search!
Mike
Mike
It sounds like a decent truck for the age, but I would be careful. The pull to the left could be more than just an alignment. It might be worn front-end parts or something to do with the lift. That stuff can get expensive fast.
The rebuilt transmission is good, and it’s nice you saw a receipt. That’s a big plus.
Before you buy, I’d suggest getting a full vehicle inspection report. A good mechanic can check the frame, suspension, and steering parts. With 239k miles, it's smart to know what you’re getting into.
If everything checks out, and you're okay with fixing the small stuff like the window and seat, it might be a good deal. But don’t skip that inspection. It can save you from big problems later.
Hello,
This truck can still work if everything is checked. The 239k miles is high but a 24V diesel can last if it was maintained. The transmission was rebuilt, which is good.
The pull could be alignment or suspension. Make sure the lift was done correctly. The driver window and seat tear are minor issues.
Before buying:
Get a full vehicle inspection report to check chassis, suspension, and frame.
Check steering, brakes, and tires closely.
Make sure there are no hidden leaks or rust in the frame.
If the report is clean and alignment fixes the pull, it could be a reasonable purchase.
Before buying:
jmccart
16
Jan 12, 2008 05:35 PM
morkable
May 16, 2007 01:41 AM
CobraCTD
Mar 29, 2007 10:49 PM
summerfun
Jul 7, 2006 07:34 PM
00 5.9 ctd
Feb 12, 2006 08:58 PM
