Sponsored by:
Sponsored by: CARiD
state inspections in your state?
Old Apr 4, 2006 | 04:13 AM
Danderson's Avatar
No inspections in Ca to my knowledge. Good thing as my tranny controller and pacbrake set off my cel light. Electrical tape to the rescue or pull the bulb. I periodically scan it for additional codes.
Old Apr 4, 2006 | 04:22 AM
Rauschbo's Avatar
No inspections here - yet, but they do the emissions testing; The bonehead at my last test told me to "floor it and hold it until I say "Stop" - I made it CLEAR that this would not happen, diesels aren't supposed to run at 3500+ rpm, and he should check the procedure....which is to stomp and release the go-peddle 3-times, the amissions are averaged across the 3 "runs". Passed with lower readings than any other vehicle I've ever had tested (including my old '95 Civic)....
...I think it's a waste of time!
Old Apr 4, 2006 | 06:00 AM
Willy91's Avatar
$0, never have had an inspection here.
Old Apr 4, 2006 | 07:50 AM
3500Dooly's Avatar
Originally Posted by P.J
Nada!
No inpsections! No emmissions for diesels either!
You only have to inspect when a car transfers in MD, and they don't make you when you buy or are given a vehicle from a family member.
thats insane an inspection is needed every year (in my opinion)
maine's rule of thumb is if they can see rust holes- like the cab corners and fenders of any truck that has done some muding- they wont pass it,there tough up here.
Old Apr 4, 2006 | 08:05 AM
Buckshotmckee's Avatar
No inspection or Diesel smog in Ca.
Old Apr 4, 2006 | 08:21 AM
JD730's Avatar
Diesel powered pickups registered 10,000 lbs. and up do not require NJ state inspection, they fall under self inspected. I would recomend carrying a copy of the law and something that looks like some maintanace records. At 18,000 lbs and up they require a smoke test.
Old Apr 4, 2006 | 08:32 AM
RustyJC's Avatar
Originally Posted by 3500Dooly
oh...and do you also get charged double (or more) on the interstate just for dual wheels. this seems a little nuts but nothin i can do about it if these are just the state laws
Nope. The Harris County Toll Road Authority (Houston area) charges by the number of axles - it doesn't matter how many wheels are on each axle.
Rusty
Old Apr 4, 2006 | 08:50 AM
Mcmopar's Avatar
NC-11.00 inspection no emissions on the oil burners, I think 33.00 for an OBD-II car or truck, both emissions and safety. They kill me on my regi. with a 13K GVW!!
Old Apr 4, 2006 | 10:03 AM
roadranger's Avatar
Originally Posted by blord
Colorado - $45 for 2 year emissions test. Cars cost $12. Diesels have to be dyno'd cars do not.
Diesels have to be done EVERY year, cars go every other year.
Only along the Front Range.
Old Apr 4, 2006 | 12:29 PM
hubmonkey's Avatar
They did away with them a few years ago here in OK.
Hub
Old Apr 4, 2006 | 12:45 PM
6Lpowerstroke's Avatar
No tests here either and my truck wouldnt pass anyway plus i think it would be exempt because of age.
Old Apr 4, 2006 | 12:58 PM
Patrick Campbell's Avatar
I agree in AZ they told me to floor it and hold it.... I told them to stuff it.
Here in NJ I do not have to do inspection or emissions because GVWR is over 10,000 and less than 18,000. Otherwise inspection is free here and lasts 2 years. Inspection and emissions all happen at the same place...
Old Apr 4, 2006 | 01:48 PM
infidel's Avatar
What's an inspection?
In Montana no vehicle or smog checks for diesels or gassers.
We also have a lifetime registration option for rigs over ten years old, pay once and it's good for as long as you own the vehicle.
Old Apr 4, 2006 | 02:21 PM
edwinsmith's Avatar
How much does that lifetime reg. cost? What are the residency requirements up there?
I once had tags in Oregon which were $20 for 2 years. I live in a RV so I move around a lot.
Edwin
Old Apr 4, 2006 | 04:25 PM
newriverSpecon's Avatar
Depends on the county. In Pima they just have a 50 mph run. In Maricopa (in PHX metro or if you commute to PHX for work) you do the three time to th floor. Which with a loud cummins can be 1800 rpm.
Randy
