Royal Purple oil?
It's rather neat stuff, actually. It's actually purple, but if you ever catch a wiff of it - you'll never forget it. If you're really looking for an upgraded gear lube, try Castrol optigear - just hold on to something when you get a price quote...
I have it in my NV5600 for about 20k miles now, and it really smoothed it out over the stock Penzoil fill. Also I'll be putting it in my diffs when i get to that eventually. I wouldn't hesitate running it in the engine either, but i get a 10% discount on Rotella and I've been using it all along anyway so I'll just stick with that.
The Best ! i Use Long Rider (RP) It Is The Best Hands Down ! I Run It In every Thing From My Lawn Mower To My New Dodge . Go To There Web and Read About It . Made in Tulsa Oklahoma ,Office On Harvard ,Great Bunch of Guys ! Tell Them i Sent Ya .
Regards,
Col.
Regards,
Col.
RP Synchromax is too light of a lube for the NV5600.
MikeyB
Originally Posted by MikeyB
What RP lube are you using in the NV5600? RP doesn't have a lube that's compatible with the NV5600.
MikeyB
MikeyB
What do you recommend?
http://www.royalpurple.com/techa/tranxref.html
Synchromax is mainly used in manual trannies that require ATF fluid.
I highly recommend something a little thicker, like Redline MTL, Amsoil MTF or Pennzoil Synchromesh Fluid if you do any towing, especially heavy.
MikeyB
MikeyB
MikeyB
MikeyB
I tried RP in my 5600 and in less than 2 weeks it was almost undriveable because of difficult shifting.
Dumping in some Lucase ATF additive helped enough to where I could drive it and get at least a LITTLE mileage from it before I dumped it.
Now I'm running a "cocktail" of MTL, Pennzoil synchromesh (MS9224), Shcokproof Lightweight, Lucas ATF additive, and Lube Gard LXE gear additive.
Works well thus far. Good shifting all around!
Roperteacher
Jul 15, 2007 07:11 PM
gerry
25
May 23, 2007 09:09 PM
jeepsuck
Dec 26, 2005 02:17 AM
PowerstrokeThis
Mar 10, 2004 12:12 PM
