Royal Purple vs. Mopar gear oil???
Old May 19, 2007 | 02:29 PM
gerry's Avatar
Hey all...
Well I was in the dealer the other day and bought 8 quarts of Mopar synth 75/90 gear oil so I could change out the front and rear Diff Fluids...
Well I also stopped by 4 wheel parts and decided to get the Mag hytec rear cover.. That took all 8 quarts (AT $22.00 per quart!!!!!)...
Went back to the dealer today to buy 4 more quarts but they were closed..
SO here is the rear question... Since I used up all of the dealers Gold.. what do you guys think of the royal purple Synth 75/90 Gear oil.. Should I use it in the front or wait for the dealer stuff???
Gerry
Old May 19, 2007 | 02:35 PM
ken white's Avatar
I have used a variety of gear oils and RP is fine.
Old May 19, 2007 | 06:02 PM
Lrdchaos's Avatar
Save your self some money and use something other than mopar....I have used Rp in my 02, I am using amsoil in this truck. Both great oils, and alot cheaper than mopar.
Old May 19, 2007 | 08:05 PM
1sttruck's Avatar
Mobil 1 75W90 is about $9 a qt at some places.
Old May 19, 2007 | 09:11 PM
C Schomer's Avatar
RP 75w90 for sure. I'm thoroughly sold on RP gear lubes. Not that there aren't other good ones but RP has taken care of gear lube problems I've had so I stay with it. IMO, the DC 75w90 is crap! Craig
Old May 19, 2007 | 09:28 PM
gerry's Avatar
Cool... Thanks everyone...
So I have the DC synth lube in the rear and RP synth up front....
That stuff is actually purple to!!!
Gerry
Old May 19, 2007 | 11:49 PM
CatDiesel_762's Avatar
Go with royal purple. I have heard DC Synthetic still need to have a addive for the limited slip, even when they say they do not need it. I have read some where that DC was now putting the Limited Slip fluid in the rear differentials due to the large customer complaints and warranty service about gear whine or chatter with out the additive.
Do a google search on Mopar Gear Lube or AAM Fluid Type.
Shawn
Old May 20, 2007 | 09:53 AM
RunninLean's Avatar
RP is all I run.
Old May 21, 2007 | 10:28 AM
topless's Avatar
I would run Redline or Amsoil. I burned up a rear end with RP. Had a friend burn up his 1T rear end with it while towing.
Old May 21, 2007 | 11:09 AM
Rollin' Smoke's Avatar
just did my diff's last week and used the RP 75w-90 and everything seems to be good.
Old May 21, 2007 | 11:12 AM
C Schomer's Avatar
That just goes to show ya' - anything can happen! In my case, I had a D80 that was in good condition and the gear teeth were nice and shiny when I tried Ams 2k 75w90. At 13k miles I had ring and pinion howling and the UOA came back very bad. Then I changed to RP 75w90 and after another 3k miles, the noise went away but the teeth were never shiny again. I also always had wear metal on the magnet. MANY 1000 miles later I replaced the carrier and pinion brgs but kept the same gears and by that time I progressed to RP 85w140. Voila... even after 24k on the 85w140, no more wear metal and UOA was excellent and for the first time ever, the temp was under 250, towing. I don't doubt that something can fail with RP but we don't know all the circumstances about yours and your friends but I'm sure something else was going on there - previous damage, didn't run the right weight, ran the level too low, etc. I've used other Ams products that were good but not all of there (or pick any brand) stuff works for eveyone, every time. I just know in my case that RP was successful when Ams and two other brands weren't. Craig
Old May 21, 2007 | 11:16 AM
very true.....there are always different circumstances that cause things to break or wear.
Old May 21, 2007 | 11:44 AM
TPilaske's Avatar
I used RP for the diffs and the PS fluid in my last truck. I just did my diffs on this truck this w/e with Amsoil. The Mopar junk that came out didn't look so swell! I should have grabbed some and sent it in for analysis. I just know I would never buy anything from the dealer that I didn't absolutely have too!
Tony
Old May 21, 2007 | 01:16 PM
DBLR's Avatar
Tony
Did I read this correctly that you used Royal Purple trans fluid in your 2006 Dodge power steering pump? If so I didn't know that RP made an AFT+4 trans fluid. The last time I looked at the RP line they only made Dexron trabns fluid and that type IIRC can't be used in 2001 and newer Dodge transmissions or power steering pumps only AFT+4.
Old May 21, 2007 | 01:23 PM
Thunderjet's Avatar
I see people using the rp75/90, I was told that the rp75/140 may be better in the summer since I tow alot. Opinions?
I bought the rp 75/140 but have not put it in yet
tj
