Sponsored by:
Sponsored by: CARiD
Old ford tractor
Old Apr 6, 2012 | 02:43 PM
bannerd's Avatar
Old ford tractor
Hey all, the tractor took a crap today. It's a 1960's tractor, took the valve cover off the diesel engine.. found a cracked leak off tube.
The tube looks like this, there has to be away to fab one up for less cost? Any ideas?
http://www.ebay.com/itm/Fuel-Injecti...item4cff9814ef
Old Apr 6, 2012 | 07:23 PM
JD730's Avatar
Where is it cracked? How good are you at brazing?
I would either rebuild it using the old banjo fittings with new tubing or depending on how its cracked braze the old one up.
Either way you decide to do it, it has to be sealed because you won't know its leaking till the oil is super diluted with diesel.
Old Apr 8, 2012 | 10:07 AM
DiezelSmoke's Avatar
You said it took a crap? What exactly is wrong, the part you are showing will only cause a fuel leak if cracked it will stay running. Brazing will fix that problem.
Old Apr 8, 2012 | 06:11 PM
pwregan's Avatar
old ford tractor
Are the parts still available- your link shows an ebay item?
by the time you pull the old out and monkey around trying to fab up a new one or chaseing cracks in the old- for 70.00 dollars it seems more effective to just replace the bad part- what is your time worth?
ckt_santiago
Dec 26, 2018 03:55 PM
Dodgezilla
Nov 6, 2011 04:13 AM
sled4fun
Dec 2, 2008 11:39 PM
chariotdriver
Oct 18, 2008 10:50 PM
reidry
Mar 9, 2006 02:28 PM
