Sponsored by:
Sponsored by: CARiD
Need help with friends ford
Old Feb 16, 2007 | 07:07 PM
smokeum99ta's Avatar
My friend has a 02 or 03 ford f-350 with the 7.3 power stroke in it. He say's that it will start up fine but after twenty minutes or so it'll just die. After that it'll start right back up and die over and over again after every twenty minutes or so. He claims it's got a new fuel filter in it. Anyone have any idea's as what could be wrong????? If it matters he got some sort of programer,intake and exhaust. Thanks Ken
Old Feb 16, 2007 | 07:17 PM
Hippie816's Avatar
try replacing driver side battery have heard my buddy say this before and that was the problem
Old Feb 16, 2007 | 07:18 PM
I'll pass on the info to him. Thanks
Old Feb 16, 2007 | 07:23 PM
MikeyB's Avatar
Might check to see if it's the camshaft position sensor. Common failure item for the 7.3 Powerstroke.
MikeyB
Old Feb 17, 2007 | 12:37 AM
CGA03's Avatar
CPS that would be your problem.
Old Feb 17, 2007 | 09:26 AM
Hvytrkmech's Avatar
I'll vote on the cam position sensor here also, the signs and symptoms you are describing are the classic pending failure issues and will continue to get worse and/or just outright fail. A week battery will usually cause an extended crank to start but will not cause a stalling condition. Also if you do decide to change out the batteries change both and not just one. International will have a cmp for half the cost of Ford just tell the parts people you need a cmp for whatever year truck your buddy has and tell them it is for a T444E engine.
Good luck, Tim
Old Feb 17, 2007 | 01:23 PM
Bingo......He bought a cam sensor and now its fine.He sends his thanks. You guy are two for two with my friends trucks (one ford and one chevy)now just need to figure out want my problem is.
Old Feb 17, 2007 | 05:29 PM
midlife crisis's Avatar
Roger that "Common Problem"
He should carry a spare in the GB. Mine just went @ 147k. Easy way to tell is watch the tach when she's cranking w/ no fire. No tach-no cps-
bluebull
Jul 6, 2007 03:55 PM
JKM
Oct 27, 2006 05:11 PM
KBennett
Oct 18, 2006 12:11 AM
