Sponsored by:
Sponsored by: CARiD
Left OK and on the way to AK!
Old Dec 24, 2008 | 10:16 AM
13ALPHA's Avatar
Well, done and graduated. The pic is me taking the wife's car to be shipped up there. Spend some time with family in CO then start heading north! The truck drove great, kept it at about 60 and averaged 15 mpg. I just need to buy my own trailer now!
Got all heaters/warmers installed, mounted a little box inside the bumper so I can just open the winch door and pull out my cord to plug in, I like it.
Only concern before the long trip is I've got the leak between the PS and VAC pumps. It's there, but slow. I should be ok as long as I maintain fluid levels if needed right? There's no other risk? I am wondering if I should go ahead and just get that fixed while I'm on leave. Thanks, look forward to driving through Canada and hopefully seeing some trucks!
Old Dec 24, 2008 | 01:15 PM
rich's Avatar
i nwould say keep an eye on it but if you have time i would fix it takes about half day if i remember right
Old Dec 24, 2008 | 01:40 PM
dodgeguy71's Avatar
Mines been leaking at the same spot for awhile now, just check the oil and keep on going. Works good as a rust preventive during the winter/throw down the salt in the road times. I know somebody offers a kit to fix it and like rich said not to long to fix.
One thing I did notice on mine when going on long trips back to upstate NY. The oil level would be fine and then several hundred miles into the trip it would belch some oil at that spot, then the oil level would be down. I'd top it off at a truck stop and go on the rest of the way(800 mile each way). Then on the way back it would do it again. It would be oily right at the PS/vac set up. It don't do it while doing my average routine around here though. Keep some of your brand oil in the truck and you'll be ok or get it fixed, either way both of us will have to get it fixed at one point.
Good luck on the drive, always wanted to drive the Alaskan Highway.
Old Dec 24, 2008 | 08:02 PM
haloman's Avatar
I would find a cheap set of mud flaps to stick on there or that car will probably have all kinds of scrathes on it. Be safe on your trip.
Old Dec 24, 2008 | 11:32 PM
13ALPHA's Avatar
Yeah, I figure it will need to get fixed sometime, I may as well get it done now before the big drive.
I won't be towing the Subaru the whole way, I actually dropped it off in TX to be shipped up there. Thanks for the tip though Haloman!
Old Dec 25, 2008 | 07:10 PM
SuperiorRam's Avatar
elmandorf???
Old Dec 26, 2008 | 09:23 AM
13ALPHA's Avatar
Originally Posted by SuperiorRam
elmandorf???
The lovely Ft Wainwright!
Old Dec 26, 2008 | 03:52 PM
woodperson's Avatar
Driving to Alaska this time of year? Should be pretty and interesting. We made the trip this summer. Get the truck fixed before you start out. As you may know, services are pretty far apart and not real complete at each stop on this trip. And the cell phone does not reach in a lot of areas.
Where you going in AK? If you go thorugh Prince George, BC there is a dodge dealer that gives good service if your truck needs some attention.
Old Dec 26, 2008 | 08:47 PM
13ALPHA's Avatar
Yeah the winter drive should nice, no potholes right? I am PCS'ing and have no choice about the timing though.
We're going to end up in Fairbanks or North Pole, still waiting to find a house!
Does anyone have a good guess at what it should cost for the seal to be replaced? I don't have the time or tool with me at this point, they're already on a truck to AK!
Old Dec 27, 2008 | 02:24 AM
roughstock's Avatar
Why are you headed north if you are going to Arkansas? AK right?
Ha just kiddin.
The seal kit for the ps and vac is only like 13 dollars at cummins. Easy fix only took couple of hrs. Take off intake tube and pull PS/vac as one unit.
Also take spare fuses, belt, feul filter.
Have fun
Old Dec 27, 2008 | 01:06 PM
Little03's Avatar
Not sure which way your taking to Alaska if you are coming through my neck of the woods its about -20*C now and might get to -40*C on you way up here.
Old Dec 27, 2008 | 01:20 PM
ofcmarc's Avatar
Make sure you bring along some shorts and suntan lotion. We're getting almost 4 hours of daylight and its -25*F today and dropping to around -40/45*F for a week or so. It'll be colder around the AK/ Canada border. bring some good anti-gell with you along with a few spare fuel filters just in case.
Read this.
http://newsminer.com/news/2008/dec/2...terior-alaska/
Old Dec 29, 2008 | 04:26 PM
13ALPHA's Avatar
Read this.
Got diesel911 and two jugs of Howes diesel anti-gel/lube additive. I can't wait. We will be going from Great Falls, MT to Edmonton, then Dawson Creek and the ALCAN rest of the way.
Old Dec 29, 2008 | 06:40 PM
Little03's Avatar
Nice you will be going through forst st john tis where im at, travel safe.
Mountaineer
Oct 20, 2009 12:51 AM
tbarbee1
Apr 20, 2007 08:38 AM
35" 05'
Sep 12, 2006 06:00 PM
600 Megawatts
26
Jul 14, 2005 06:04 AM
