Sponsored by:
Sponsored by: CARiD
leaf spring disassembly, sorta..?
Old Sep 22, 2009 | 09:19 PM
prochargeddart's Avatar
well, im installing lift blocks in the back, and i have the perfect height figured, but i gotta remove the 2 factory blocks that are at the bottom of the leaf spring pack. if you remove the 2 bolts that hold the spring pack together, you can push loose them from the bottom, but the bolts are sort of fastened to the little factory shims (peices of a leaf, same size as a block) can i just run grade 8 bolts through the spring pack and call it good? or do i realy need to do some sort of thing like that again? thanks
littlebuddie
Sep 4, 2009 11:02 PM
nevems2ret
Jan 5, 2009 07:31 AM
wadecool
Feb 2, 2007 07:33 PM
reb0957
Dec 9, 2006 10:06 AM
linella
Dec 5, 2004 06:42 PM
