Headlight disassembly??
Old Jan 3, 2009 | 11:54 AM
nevems2ret's Avatar
Anyone taken a 3rd Gen Ram headlight appart. Need to remove the 2 adjusters bolts and clean the corrosion from the threads. Adjusters are attached to the back with 2 screws. Met with resistance when I took the screws out and tried to slide the adjuster out of the assembly. All tips greatly appreciated.
Mike B
Old Jan 4, 2009 | 08:11 PM
carl48's Avatar
i had mine apart when i changed them to hid projectors i pulled the lense and adjusters out and trashed them , it looks like the adjuster bolt was attached to a pivit ball on the reflector lense before the clear lense was installed ,i would try to clean and lube the bolt where it go's through the block with the two screws
Old Jan 5, 2009 | 01:06 AM
nevems2ret's Avatar
Thanks Carl48. Dug through my junk and found a headlight I crunched hitting a cow a couple of months ago. Agree with you, the thing has to come apart from front to back. No other way.
Mike B
Old Jan 5, 2009 | 07:31 AM
Totallyrad's Avatar
Take a look at this thread. I believe it's just what you're looking for, and a little more. https://www.dieseltruckresource.com/...ack+headlights
prochargeddart
Sep 22, 2009 09:19 PM
littlebuddie
Sep 4, 2009 11:02 PM
wadecool
Feb 2, 2007 07:33 PM
reb0957
Dec 9, 2006 10:06 AM
linella
Dec 5, 2004 06:42 PM
