clutch disassembly question
Old Feb 2, 2007 | 10:54 AM
wadecool's Avatar
I have the tranny out and the bellhousing off. Can you guys tell me what to take off next so I can inspect the clutch and flywheel? Also, what should I look for to make sure everything's ok(clutch,flywheel,bearings,etc.)? Thanks in advance for your help.
Old Feb 2, 2007 | 04:34 PM
Contractor's Avatar
Wade,
Next would be to unbolt the pressure plate from the flywheel. 6 bolts I think. You want to loosen them evenly a little at a time unless you are getting a new clutch anyway. the disk is behind that. Check for burns on the p-plate and flywheel and material left on the disk. The TO bearing should spin free as well. Since you already have gone this far though, I would just replace the disk, PP, and bearing.
Cole
Old Feb 2, 2007 | 07:33 PM
Tate's Avatar
Don't forget the pilot bearing. Mine was all rusty and missing needles when I did my clutch.
prochargeddart
Sep 22, 2009 09:19 PM
littlebuddie
Sep 4, 2009 11:02 PM
nevems2ret
Jan 5, 2009 07:31 AM
reb0957
Dec 9, 2006 10:06 AM
linella
Dec 5, 2004 06:42 PM
