just bought a "new" tractor!!
"New" being a 1970 Case 530
with a construction king loader, backhoe and a diesel that has a bit of blow-by!! I drove it home yesterday, and sure it smokes out the oil fill cap a bit, but I LOVE it!! I paid $4000 for it, and the hydraulics are AWESOME! It starts up good in the cold (about 25* f) with a sniff of happy gas. It was not plugged in. I think I did good! bruce
J.I. Case 530 CK Construction King
Production years: 1960 - 1967
Next model: J.I. Case 580 CK
Tractor type: Industrial tractor
J.I. Case 530
Production years: 1960 - 1969
Tractor type: Farm/Agricultural tractor
Overview
Engine
Transmission
Dimensions
The 530 was also used as the 530CK (Construction King) loader-backhoe, although with significant modifications.
J.I. Case 530
Overview
Engine
Transmission
Dimensions
The Case 530 Construction King was based on the Case model 530 tractor. It was available as a bare tractor, loader tractor, or with loader and backhoe. The tractor chassis was built in Racine while the loader and backhoe were built in Burlington.
Production:
Manufacturer: J.I. Case
Factory: Racine, Wisconsin, USA
Burlington, Iowa, USA
Total built: -unknown-
Original price (USD): Open operator station.
J.I. Case 530 CK Engine:
J.I. Case 4-cyl diesel
J.I. Case 4-cyl gasoline
full engine details ...
Capacity:
Fuel: 22 gal [83.3 L]
Hydraulic system: 4 gal [15.1 L] (tractor)
5.5 gal [20.8 L] (loader)
11 gal [41.6 L] (loader-backhoe)
3-Point Hitch:
Rear Type: I (optional)
Power Take-off (PTO):
Rear PTO: independent (optional)
Rear RPMs: 540
Dimensions & Tires:
Wheelbase: 77.2 inches [196 cm] (gas)
78.4 inches [199 cm] (diesel)
Weight: 3280 to 9345 pounds
Front tire: 7.50-16
Rear tire: 14.9-24
full dimensions and tires ...
J.I. Case 530 CK attachments:
front-end loader
backhoe
all 530 CK attachments ...
530 CK Serial Numbers:
1960: 8160001
1961: 8168801
1962: 819001
1963: 8208001
1964: 8229001
1965: 8253501
1966: 8279001
how to read serial numbers...
Links:
Mike's 530CK data: information and manuals for the 530 Construction King
J.I. Case 530 CK Power:
Engine: 48 hp [35.8 kW]
Mechanical:
Chassis: 4x2 2WD
Steering: hydrostatic power
Brakes: differential manual disc/band
Hydraulics:
Type: optional
Capacity: 4 gal [15.1 L] (tractor)
Pressure: 2000 psi [137.9 bar]
Valves: 2 (optional)
Total flow: 22 gpm [83.3 lpm] (2100rpm)
20 gpm [75.7 lpm] (1900rpm)
Electrical:
Ground: positive
Charging system: generator
Battery:
Number: 1 (Gas)
2 (diesel)
Volts: 12 (gas)
6 (diesel)
Page information:
Last update: August 6, 2010
Copyright: Copyright 2010 TractorData LLC
Contact: Peter@TractorData.com
Production:
Capacity:
3-Point Hitch:
Rear RPMs: 540
Dimensions & Tires:
Front tire: 7.50-16
Rear tire: 14.9-24
front-end loader
backhoe
1960: 8160001
1961: 8168801
1962: 819001
1963: 8208001
1964: 8229001
1965: 8253501
1966: 8279001
Links:
Mechanical:
Chassis: 4x2 2WD
Hydraulics:
Type: optional
Electrical:
Ground: positive
Battery:
Number: 1 (Gas)
2 (diesel)
Volts: 12 (gas)
6 (diesel)
Page information:
You guys are AWESOME!!
Yep, pretty much all my ?s were answered with that post!! The bucket needed new teeth tips, and someone had welded the holes in and welded the other tips on, so I just welded these on too. I plugged it in, and it didn't need any happy juice to start this morning.
Now to fill in our new culvert/root cellar
Tyler_02
May 30, 2012 08:49 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
02Texas_Rattle
Nov 12, 2003 12:46 PM
