Sponsored by:
Sponsored by: CARiD
Interesting Cummins 6.7L info on Ford's Commercial Vehicle site
Old Jan 16, 2007 | 02:50 PM
RC51's Avatar
https://www.fleet.ford.com/truckbbas...ingsession.pdf
Looks like the 6.7L is available with 750 lb-ft of torque for the F650/750 trucks. Also note the statement "Aftermarket exhaust brakes prohibited due to DPF regenerative cycle strategy"
Also, wander if the Cat C7 is using the same turbo as Cummins now?
The F650/750 requires an air defuser on the exhaust tip to mix cool air with the exhaust. I haven't noticed any defusers on the C&C's on the lots.
Old Jan 16, 2007 | 02:52 PM
dodgezilla04's Avatar
the 6.7 being rated at 750ft#'s says good things for those buying one, if left stock at 650ft#'s it will last a VERY long time at a power level below its design rating. just like the marine 5.9's being rated at 400+hp continuously, gives us lots of growing room in the power department.
Old Jan 16, 2007 | 03:09 PM
Jfaulkner's Avatar
Muted User
Amazing how much continuous power you can get out of somthing when you have an "endless" supply of cold water.
Old Jan 16, 2007 | 03:20 PM
Jfaulkner's Avatar
Muted User
Any '07 Cat engine that doesn't have twins has a VGT. Here.
Old Jan 16, 2007 | 09:07 PM
grantx5's Avatar
Question
Why don't they put the 6.4 in?? Why use a CAT or Cummins??
Seriously, why not? Is there an inherent problem with the PSD?
Old Jan 16, 2007 | 09:27 PM
zontral's Avatar
It probably will have the 6.4 as an option eventually. Just like how the 6.0 was an option before, but with internationals ratings for the engines. Most of the f650's I've seen had cats or powerstrokes in them, I've seen very few with cummins.
Old Jan 17, 2007 | 11:25 AM
Luke S's Avatar
That is interesting? I read that whole thing and saw nothing about the 6.4 being offered. Wonder why?
Old Jan 17, 2007 | 11:27 AM
Luke S's Avatar
Ive seen very few with Powerstrokes. Everything I have seen has had a Cat or Cummins. I had a customer that had one that I sold for him a month after he bought it because he said it was the most worthless truck he had ever owned. It had a 6.0 PS.
Old Jan 17, 2007 | 01:48 PM
Smkn600CTD's Avatar
Its probably because Ford doesn't want the commercial side of the business to be stuck with warranty issues and left on the side of the road.
As for the rest of the population that buys a 6.4L, thanks for R&D
Old Jan 17, 2007 | 04:01 PM
Jfaulkner's Avatar
Muted User
I think anytime you put a pickup truck engine in a larger truck your asking for problems. I don't care if it's a PS, 5.9 or the Dmax. An underpowered truck works alot harder than needed, never gets the fuel milage the owner might have hoped. Why send a boy to do a man's job?
Old Jan 17, 2007 | 06:02 PM
That man has it right. Not buying enough engine is false economy.
Old Jan 17, 2007 | 06:42 PM
dodgeguy71's Avatar
That's kinda like a 1 ton pickup with the gas V-8 in it. I test drove a few and they were some worthless cows! Or a half ton pickup with that useless 3.7L V-6. Guy came into the dealer one day with around 2000 miles on it and said it was weak, no power. Under the hood, 3.7L, I went out and test drove it and told the forman it would'nt pull a greasy string out of a hogs butt, he said, "that's normal".
Old Jan 17, 2007 | 11:57 PM
PaulDaisy's Avatar
Just wait until the tree huggers talk someone high up into a Hybrid I can only imagine what THAT would drive like. Well of course, one could put a 700 kW motor under a 1 ton truck's frame and fill up the GVW with Ni-Cd batteries, and I bet that truck would outpull and outstart anything ever made... but replacing the batteries would get expensive quickly
-P
Old Jan 20, 2007 | 06:29 PM
Equalizer 2's Avatar
[QUOTE=PaulDaisy;1306327]Just wait until the tree huggers talk someone high up into a Hybrid I can only imagine what THAT would drive like. Well of course, one could put a 700 kW motor under a 1 ton truck's frame and fill up the GVW with Ni-Cd batteries, and I bet that truck would outpull and outstart anything ever made... but replacing the batteries would get expensive quickly
-P[/QUOTE
This is already being talked about. Here is a link where I saw it.
]http://www.rv.net/forum/index.cfm/fu...d/18971656.cfm
Old Jan 21, 2007 | 06:35 PM
DryCreek's Avatar
All Gas V-8's bad?
Originally Posted by dodgeguy71
That's kinda like a 1 ton pickup with the gas V-8 in it. I test drove a few and they were some worthless cows! .
Have you ever driven the Chevy BIG block (496-8.1L) with a six speed? I drove a friends, and it seemed to do pretty well. Lots of grunt way down, and fair economy to boot. My old 454 with the NV4500 and 4.10:1 rear end wasn't a race car, but it didn't seem gutless. I just don't see a small block doing as well as either of those large block gassers. Too bad the 8.0 V-10 Dodge offered is now gone.
Dry Creek
