Int. PT365A questions.
I am looking at a 4 door dump truck with a crate International PT365A and an Allison 4 speed auto. Anyone know these motors/trannys and have any input? What is the hp? Any problems with motor or tranny?
That wouldn't be a DTA360, would it? It's about the right year and weight for one of those. Reliable but won't pull the skin off a rotten banana. HP is probably in the 150 range. The Allison is probably a 545, they give good service. What do you expect the truck to be able to do?
All the info that I have now, he gave me the motor numbers and said it did have a turbo. It would be used for a non-profit organization that needs the crew cab to haul alot of people and they haul stages, skateboard ramps, sound equipment, a 17K lb. backhoe, and building supplies. Sometimes they go cross country (not with the backhoe). If it is a powerstroke i don't see how it would have enough power to pull itself down the road.
The guy said he bought it to tow his rv and then went another direction so maybe thats why?
Sure its not a DT466A? Thats what our '82 crew cab International has in it. A DT360 won't be a powerhouse, but it will get you there. Towing the backhoe around will be probably the toughest thing.
I know guys that ordered them new with the DT360 and regretted it, wished they would have ponied up and got the DT466 from the start.
I will have to call the guy and see just what motor it does have. We are not that flat here and they tow the backhoe from S. Ca. to property on top of a mtn in Az. If the motor is the 7.3L I think they should pass. Thanks for the info.
It is most likely a dt 360, as others have stated not a huge power house but extremely reliable, if the truck has a 28,500 gvw then it is most likely a 1900, not a 1700.
GO 4LO
15
Jul 28, 2004 01:47 PM
whytywythnostyle
Mar 16, 2004 09:13 AM
Diesel Freak
May 3, 2003 09:40 PM
